xB turbo!!!
There is a shop near me that will custom build a turbo kit for the xB if there is enough interest. I am good friends with these people and they are willing to invest the time to fab something. They are very reputable and know exactly what they are doing. If interested please send me a PM. Keep in mind that it has not been made yet but could be with enough interest.
let me tell you the demand is high. the only problem is there has been a turbo kit around for some time now. they never put it into production as the fuel management has to be worked out. with the stock fuel and 6-8lbs of boost, the motor lasted 6 months daily driven until a rod snapped. basically the internals have to be built to hold the boost
Originally Posted by TheScionicMan
It's not the strength of the rods, it's the offset angle of the crank. It aids in economy, but doesn't work well with boost. They designed the motor to run as is...
Basically, I'd like to know how they would handle the fuel management, new higher flowing injectors, rods, and what psi they plan on running. We all know the engine can't handle anything above 7 psi max.
Originally Posted by superjeer
"Ya know what, I got one of dem idears. Yeah, its my idear and no one elses. "
Is that Paul Sr?
Is that Paul Sr?
The car can live in boost over 7lbs. The problem is, the static C/R + boost pressure makes a completely absurd final corrected C/R... it's FAR too high w/o removing timing or adding some sort of knock suppression.
The rod/piston setup aren't very forgiving when it comes to knock.
Originally Posted by crestronwizard
So what are you doing now?
Turbo: Left over TSI kit piping modified to fit correctly, front mount from TSI kit, Precison GT28R, custom stainless manifold.
Engine: TBA...
Drivetrain: Stock tranny/axles, SPEC Stage 3 clutch.
Any more questions ?
Anyone want to buy my Garrett T20 and cast manifold?
Engine: TBA...
1st: what is the stock injectors, and are the GT-S injectors drop in?
2nd: why using a 1:1 RRFPR? I though most honda type are something in the ball park of 12:1, or 8:1?
3rd: Are you running the injectors straight off the E-manage?
4th: How was the TSI kit? have any picturse of this kit installed?
5th: Who did your custom SS manifold? have pictures of this?
6: Are you building your block? If so, got any tips on what to look for, or where to source parts so I don't need to custom order all the parts, or is everything custom made? Like Cunning rods, Arias pistons?
7: Got any #'s for the TSI kit? How well does this kit rank up? It's relitivaly cheap, and looks to be a decent bargain. Does this kit fit a bean (xa)?
Got pics of the cast manifold and Garrett T20?
