straight rear strut brace VS triangulated rear strut brace
Old Nov 9, 2011 | 03:06 AM
DieselDragster99's Avatar
Default straight rear strut brace VS triangulated rear strut brace
Does one have an advantage over another im assuming the triangulated has more support, but im new to the import game so i was curious if theres something im missing.
Old Nov 9, 2011 | 03:19 AM
Coolwaterz's Avatar
i remember the spare wheel gave rear structural support...
it got rid of my squeaking noise.
Ingalls makes a good one. but i bet u can make your own cheaper and easily.
http://www.amazon.com/Ingalls-93304-.../dp/B0058U7SZC
would be nice if theres another bar going across to connect the lower part.
Old Nov 9, 2011 | 02:53 PM
mrexotica's Avatar
Both are sparkly bits that don't do a lot structurally. Have you ever looked at your rear shock mounts? There are no towers, they are so well-braced.
Old Nov 9, 2011 | 02:55 PM
mrexotica's Avatar
What will make a difference is a rear sway bar, proper dampers, then springs.
Coilovers are generally for looks unless you spend good money.
Old Nov 9, 2011 | 03:31 PM
So I shouldnt even waste the money I guess well I'll spend that money on some good springs.
Old Nov 9, 2011 | 03:32 PM
Any suggestions for autocross? What type of springs I should use?
Old Nov 9, 2011 | 03:44 PM
XIEmperorIX's Avatar
The forum has a motorsports section fyi that would have a lot of good info on that. For auto x I know a few guys had good success with the trd springs and struts.
Old Nov 9, 2011 | 04:45 PM
Thanks I'll search for it
Old Nov 9, 2011 | 07:33 PM
Vlad1024's Avatar
For autox it's better to go stock first. Then figure out what you need to change to make it better. Don't buy lots of suspension parts without knowing what you're tuning; you may end up with a car that handles worse. That said the general consensus is that a thicker rear sway bar is very beneficial for autox.
Old Nov 10, 2011 | 04:33 AM
pinoyFMtC's Avatar
Any lower than 1.5" lower than stock will start to degrade handling. I think the TRD and H&R are as good as you can get, spring-wise. Dampers like the TRD or Tokico will help handling also.
And they're right, a rear swaybar will decrease understeer.
carid
Feb 12, 2015 11:54 AM
757_BRDFLY
Jan 9, 2015 12:29 PM
TheTripleC
Jan 4, 2015 06:46 PM
hampton1100
Jan 2, 2015 08:13 PM
DjFrOsT
Nov 6, 2003 04:54 AM
