Pads rub the rotors
Old Nov 13, 2011 | 12:54 AM
TotalChaos's Avatar
Default Pads rub the rotors
Anybody have the issue of new brake pads (driven on mine for nearly 200 miles) not pulling back off the rotor so they do not rub, especially at lower speeds? I just put on new TRD pads and when I turn after I brake, I hear the front left pads rub the rotor. Kind of ticking me off. I greased the guide pins and other contact points so not sure what issue is. Any thoughts?
Old Nov 13, 2011 | 02:44 AM
draxcaliber's Avatar
nope...did you not push the piston all the way back in when installing the pads?
Old Nov 13, 2011 | 04:13 AM
TotalChaos's Avatar
Yep....brakes stop my car fine and everything is functioning except for this rubbing. It seems to go away at higher speeds, above 10-15 mph.
Old Nov 13, 2011 | 11:21 PM
c500129's Avatar
I have the exact same thing happening to me with my EBC greenstuff with my front driver side. the rest are fine. mine also shows up if I press the brake about maybe 1/4 of the way and as soon as I apply more pressure its gone. Its driving me crazy too. Don't know what it is.
Old Nov 14, 2011 | 12:24 AM
Vlad1024's Avatar
There is nothing pulling the pads off of the rotor. They will rub slightly. Some pads will be louder than others especially on a worn rotor.
Old Nov 14, 2011 | 12:41 AM
Spicy_McHaggiz's Avatar
Exactly. All pads rub the rotors a little bit, this is likely the first time you've heard it. There is no problem unless the pads are completely engaged on the rotor (seized caliper)
Old Nov 14, 2011 | 03:02 PM
TotalChaos's Avatar
Yup....the pads do constantly rub the rotors but this is not what I am hearing...at first, I thought it was since I just changed the pads and thought maybe I did something wrong. After further analysis, without hitting the brakes and turning at slow speeds, the sound is still there. I am thinking it is not the pads or my ability to install new pads. Still under warranty so probably taking to dealer to check out.
Rob54Monty
Jan 20, 2016 01:41 PM
dougcbx
Oct 23, 2015 11:42 PM
gqdabien
Oct 8, 2015 05:36 PM
terrye
Sep 26, 2015 12:24 AM
blackpearlTC
Jul 19, 2015 04:55 PM
