2.5in or 3in exhaust ?
Old Nov 16, 2011 | 07:21 PM
tc8662453000's Avatar
Default 2.5in or 3in exhaust ?
hey guys, so im going turbo and at the moment i have full pipings 2.5in exhaust... i would like to know if i would have to go to 3in for turbo or can i just stay at 2.5in? if so whats the difference ?
Old Nov 16, 2011 | 07:32 PM
jman07jb's Avatar
Ive definitely heard 2.5 is ok unless your going for high boost then you want 3 or itll be restrictive. Theirs a couple threads around here where people talk about that run a little search
Old Nov 16, 2011 | 09:16 PM
BOOSTit06's Avatar
You can run 2.5 exhaust no problem, if 3" exhaust is not in your budget no big Deal. 3" exhaust lets your turbo "breathe" alittle easier, you will see better power numbers on a 3" exhaust.
Old Nov 16, 2011 | 10:27 PM
BadDudeTC3's Avatar
^ I agree with the above comment. I'm boosted and have a 2.5" exhaust right now and I can tell on the big end that my tC really wants to get rid of that exhaust and like the above post said, I'm sure I'll have a little bit more pull/power higher in the powerband once I get the 3" setup.
Old Nov 17, 2011 | 12:50 PM
paul_dezod's Avatar
Scionetics
KAD
Just up that turbine A/R
Old Nov 17, 2011 | 02:10 PM
BadDudeTC3's Avatar
Thanks for the advise Paul! Didn't even think about that....
Old Nov 17, 2011 | 11:50 PM
borderguy881's Avatar
my 60-1 is on a .63 ar turbine and it pullls like a bat outta hell up top compared to the 50 trim i had with a .63 all this being on a 2.5 exhaust i dont plan on doing away with it niether considering i will already be spending lots of money in the near months for a new maf a new primary o2 and a new tune the 2.5 still allows me to reach my goals which is 330 on 13 psi this being on a tune i had for my 50 trim with just fuel adjustments cant wait for the timing to be on =D
Old Nov 20, 2011 | 10:16 PM
so i talked to my builder, and he said i can leave my 2.5 as a daily driver and have a switch to an open dump when racing... im going to be running about 350hp... should i do that or just get a 3 inch ?
Old Nov 21, 2011 | 02:43 AM
BadDudeTC3's Avatar
IMO just go with a 3" exhaust and be done. Boostin these cars gets addicting and what if you get another dd and decide to up the boost even more.
Old Nov 24, 2011 | 03:04 PM
yeah thats true.. and now what oil should i use?
Old Nov 24, 2011 | 05:10 PM
BadDudeTC3's Avatar
Make sure to use a synthetic oil seeing that boost'd cars break down the oil faster than N/A cars. Personally I use Mobil 1 10w-30 but thats just my preference. I also change the oil a little more frequent cause i go to the drag strip once a month from spring to fall (April-September)....usually I change it at 2,500 miles rather than 3k.
Old Nov 25, 2011 | 01:55 AM
10w40 user here any brand synthetic thats on sale lol
Old Nov 25, 2011 | 09:53 PM
rhythmnsmoke's Avatar
Music City Scions
3 inch exhaust work great. I'm running a PTuning 3 inch exhaust and it will be the last exhaust I will ever need. Anything after that would be just a dump to the atmosphere like Rado...lol.
Old Nov 26, 2011 | 04:13 PM
blown_xa's Avatar
difference is about 20whp on lower boost levels. Switching turbine housings won't do much more than shift powerband a few hundred rpm.
Old Nov 27, 2011 | 05:57 PM
yeah, i've always use Mobil 1 synthetic oil.. but my builder said I should use this oil thats really good for turbo cars, i believe he said something about it being green
Old Nov 27, 2011 | 06:56 PM
BadDudeTC3's Avatar
Not sure about that type of oil but my kit has 30k on it using Mobil 1 synthetic so its proven to work because my kit still runs great and I don't burn a lot of oil.
Old Nov 28, 2011 | 04:43 AM
aryana159's Avatar
I had a 2.5 inch down pipe for a while moved to 3inch and noticed a faster spooltime and I could just tell the turbo breathed alot better. You might as well go 3inch dp with a electric dump if your going that route or just do a full 3inch exhaust.
brett561tc
Sep 15, 2015 06:33 AM
carid
Scion FR-S Drivetrain & Power
Jul 15, 2015 11:26 AM
LzeroKI
Scion tC 1G Aero & Exterior
Feb 10, 2015 07:28 PM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
