YIKES - Driver side floor rain water LEAK!
Old Nov 23, 2011 | 12:03 AM
dmpsk8's Avatar
Exclamation YIKES - Driver side floor rain water LEAK!
Hey guys,
So I've been battling a mysterious leak in xB for about a month now.
After a good rainy day, the driver side floor gets wet. Not like 4" of standing water, but pretty darn wet. The firewall is bone dry and the floor plugs seem to be in OK shape (I resealed them anyway). I have not cut them to run any wires. Nothing is leaking from the headliner or windshield as far as I can tell. The source seems to be lower. The rest of the floor is dry, even under the driver seat.
Today I saw a horizontal floor seam (under the white foam pad below the pedals) had a couple spots where the factory sealant was incomplete. I resealed it with epoxy, though I find it hard to believe water could find its way in through there. That panel isn't directly exposed on the underbody.
Anyway, just wanted to see if anyone had similar issues and found a common solution.
Thanks guys, tracking down a leak like this is a pain.
Old Nov 24, 2011 | 01:34 AM
Sciond's Avatar
and that was all factory seam sealer,bad install or failure? wow usually that stuff never fails
Old Nov 24, 2011 | 03:55 AM
dmpsk8's Avatar
Yep, factory.
The metal seam was bowed up a tiny bit over a three inch section, thus, the factory sealant had a gap in coverage.
I got in a fender bender last year, I'm wondering if the joint got tweaked a bit and slowly loosened up until now.
Still not 100% sure this was the source of the leak. I'll have to wait until the next heavy rain, lol.
Old Nov 24, 2011 | 03:22 PM
Sciond's Avatar
residual accident damage makes sense to me
Old Nov 27, 2011 | 09:45 PM
dmpsk8's Avatar
OK, it rained like crazy today.
I should know tomorrow if I still have an issue, I'll keep you posted.
Old Nov 28, 2011 | 03:42 PM
bbszero's Avatar
Curious. Cause i've battled leaks in both boxes, in the same location. but it's at the headliner, on the drivers side, right up against the windshield. Thought on my first box it was cause my sunroof, but my other box doesn't have one. Its only on hard rains, when the nose is pointing down hill. if its pointing up hill, nothing at all comes in.
Old Nov 29, 2011 | 12:58 AM
dmpsk8's Avatar
Well, I stayed dry today in the rain! So hopefully that seam just needed resealed. We'll see if my luck continues.
Today I was parked on a slight slope toward the passenger side. I'll try parking the opposite way tomorrow to ensure I'm good to go.
SuperXero
Scion tC 1G ICE & Interior
Feb 23, 2020 08:17 AM
mischadoll
Mar 9, 2015 05:48 AM
idriveanxa
Mar 8, 2015 12:03 PM
minter66
Dec 15, 2014 01:45 PM
jpn6438
Dec 12, 2014 08:09 PM
