BC racing coilover noise?
Old Nov 28, 2011 | 01:48 AM
RAWRbot's Avatar
Default BC racing coilover noise?
I have had my bc coils on for about 2 months a couple weeks ago i started hearing a pop/clunk noise when im slowy moving in to a parking spot. only does it when i turn right into a spot? maybe cause theyre maxxed out?
anybody else having this problem? i checked and everything is tight and in place.
thanks for the help in advance guys.
Old Nov 28, 2011 | 03:40 AM
danielv's Avatar
i have bcs and they just seem to creak a lot not, maybe check to make sure the spring and perches are seated snuggly against each other?
Old Nov 28, 2011 | 03:52 AM
jacobxahn's Avatar
/\ same
all that i get is just some squeaky noises when im making u-turns
try to isolate which area its coming from and inspect all the bolts / springs / perches make sure nothings loose?
Old Nov 28, 2011 | 03:55 AM
jaylouie's Avatar
i'm not sure if the BR coilovers come with adjustable front endlinks, but it is highly likely that the front endlinks are too long. you just need to use some shorter front endlinks
Old Nov 28, 2011 | 02:18 PM
RAWRbot's Avatar
Nothing is loose and spring, bolts, perches are on there tight. I'm thinking it might be the front end link. Would anyone know where I could find some? Adjustable?
Old Nov 28, 2011 | 07:14 PM
djshway's Avatar
Mine were quiet at first. after a few months, my rear creak everytime i go at an angle in a elevation change. EX: going over bumps, if i go at an angle, it creaks on the rears.
I've pulled it out, readjusted everything, checked every bolt, and can't seem to find the problem. Its more of an annoyance than anything, but as long as nothing is damage, im fine with it i guess lol
If you do happen to find a cure for this let us know!
Old Nov 28, 2011 | 07:33 PM
dropzone's Avatar
^Do you have an aftermarket rear sway bar? I know the TRD sway bar bushings will need to be greased again after awhile, that's the only squeaky sound I've been hearing.
Old Nov 29, 2011 | 06:56 AM
djshway's Avatar
I don't have any after market Sway, but i did come across another thread, where the guy talked about re-greasing some nooks and crannies. and he didnt hear it again? any inputs on that?
Old Dec 6, 2011 | 02:56 AM
RAWRbot's Avatar
Still got the noise and cant figure it out. :/
Old Dec 27, 2011 | 08:28 PM
deezelium's Avatar
Default bc-racing
I have had these on for around 6 months now, gotta say really un-impressed. What settings do you have yours on? I am running an arch height of 60mm which leaves little gap, have the fronts t 4mm preload and 15 and 15 on the adjusters...no matter what i do the back makes a slamming sound over bumps... thinking of getting rid of them to be honest
Old Dec 28, 2011 | 03:17 AM
RAWRbot's Avatar
My front coils have about 3 threads left and at 18clicks. My rears are maxxed and at 18clicks. I haven't messed with the preload. Could that be where my noise is coming from?
BlackKnight
Sep 15, 2015 06:42 AM
brownSys
Feb 27, 2015 04:20 PM
hampton1100
Jan 2, 2015 08:13 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
BlueBox
14
Jan 15, 2004 01:08 PM
