2004-2006.5 [NCP61]
Spark Plugs
Old Dec 1, 2011 | 06:30 PM
joey3002's Avatar
Default Spark Plugs
Is there a DIY on the site? I have not been able to find one. I am looking at doing the plugs this weekend.. Im sure its simple but just figured I would look at the process first.
tia
Old Dec 1, 2011 | 06:31 PM
Russ Lyman's Avatar
There is a DIY some where I'll find it for you
Sent from my iPhone using Tapatalk (sweet!)
Old Dec 1, 2011 | 11:13 PM
dz302's Avatar
tia
I don't see a DIY, but honestly, it's as easy as changing an air filter. Just remove the engine cover (2 bolts) and you will see the 4 coils and plug wires going into the top of the valve cover. Each coil has 1 fastener (10mm I think) holding it into place. Remove the fastener, pull the coil and the stem will come right off the plug. (You can disconnect the coil if you choose, as shown in the picture). Get your spark plug socket and remover the plug. Gap your new plug, install, pop the coil stem back on and replace the fastener. Repeat 4 times.
If you have ever changed plugs this is super simple. If not, it's still simple enough. Just be gently with all the coils and be sure not to cross thread the plugs.
Hope this helps.
Old Dec 1, 2011 | 11:53 PM
Russ Lyman's Avatar
There is one one Scikotics for a first gen xB. Same thing.
http://www.scikotics.com/forums/showthread.php?p=988518
But yeah it's simple
Old Dec 2, 2011 | 12:09 AM
joey3002's Avatar
Thanks guys, any chance I could bother you 1 last time.. for the gap? I have been told by the shop that they are already gapped but I want to verify.
Also, yes, it looks like kids play to do them. I have had a few buggers when doing plugs.
Old Dec 2, 2011 | 01:02 AM
Russ Lyman's Avatar
0.032 "
Found the write up on here
https://www.scionlife.com/forums/maintenance-car-care-1604/spark-plug-change-16364/
Old Dec 2, 2011 | 04:07 AM
joey3002's Avatar
Nice, thanks for the link. I'm looking forward to tackling this on Sat.
Sent from my htc evo using tapatalk
Old Dec 2, 2011 | 04:16 AM
Vlad1024's Avatar
Iridium spark plugs are indeed pre gapped.
Old Dec 2, 2011 | 10:17 PM
joey3002's Avatar
Just did a seafoam treatment.. She smoked good. Tomorrow I'll do oil, plugs and partial Trans drain..
Hids didn't come today maybe tomorrow..
Old Dec 2, 2011 | 10:51 PM
Russ Lyman's Avatar
What's the seafoam treatment
Old Dec 3, 2011 | 03:02 AM
joey3002's Avatar
Best I could do on my phone...
Old Dec 3, 2011 | 01:40 PM
Russ Lyman's Avatar
After watching the video I still don't know what it does. The comments said something about a better idle.
Old Dec 3, 2011 | 04:32 PM
joey3002's Avatar
Sorry, it cleans any carbon deposits.
I did the plugs (ngk iridium ix bkr5eix, oil (5w30 Fully Syn, k&n filter)
While under the car, I realized two things, I didnt have a socket to fit the trans bolt, OR a gasket for the bolt to replace the old one.
I will tackle that tomorrow, hopefully with the HID's if they come today.
But I do have a question, the plugs I took off the car were ngk R bkr5eya
Are those original or have the plugs been done by the previous owner?
Thanks again.
Old Dec 5, 2011 | 05:11 PM
JIMXB's Avatar
Thanks again.
When I did my 1st plug change, I notice NGK regular plugs came my new 2004 xB.
MeDizzy
Oct 8, 2015 03:31 PM
Renuco612
Sep 16, 2015 09:01 AM
BlingSlade
Sep 5, 2015 08:52 AM
