tC Tech and DIY Info for the Scion tC
Dome Lighting Install
Old Mar 28, 2005 | 01:19 PM
valeriecason's Avatar
DeepSouth Scions
Cool! I will be ordering bulbs today. Thanks for the excellent instructions. It's looks great.!
Old Mar 28, 2005 | 01:26 PM
LucidBD's Avatar
i just got my windows tinted this weekend and they are SOOOOO illegal! i got hardcore 5% over the OEM tint. you can stand with your face to the window and barely see who is in the car. if you stand 4-5 feet back you cant see ANYTHING. so ill have to take 1 or 2 shots at night from inside and out.
Old Mar 29, 2005 | 06:21 AM
LiNxStEr's Avatar
I need some help guys. I tried to change my lights but i turned them and the little thing were the bulb guys pop up and i had to remove the whole dome. But now my map lights wont work. Do you thing that i could of burned a the fuse? Any help would be apreciated thx. Actually i just checked the back light also and that wont turn on either
Old Mar 29, 2005 | 06:36 AM
woodstock's Avatar
woops...can someone help this guy out?
Old Mar 29, 2005 | 07:09 AM
vonplyr's Avatar
Doh! I did the same thinga fe months ago - except im not even sure how to take the whole dome housing off. Anyone know how? Is it just clips holding it in? Any input would be appreciated! thanks!
Old Mar 29, 2005 | 02:53 PM
LucidBD's Avatar
oh i had that problem with the center front housing. i turned it and it fell in. thats why in my directions above i BOLDED the words DO NOT TWIST or TURN. all you have to do to pull the grey control panel out in slide a flat head in the front..make some room for your fingers, grab with both hands and PULL down HARD. its not easy and your will not break it. trust me. then you can access the back on the housing. try moving the little bulb housings around.(i.e switch the left one to the center, the center to the left) make sure you place it in and turn it so that it makes a connection with the metal strip. test it a few times. you shouldnt have blow a fuse. not by just taking it out.
putting the grey cover back on is easy. you need to look up in the inset before you put it back. there are 2 WHITE caps that might be still stuck. need to pull those out and put them in the right positions on the control panel.
IF YOU NEED MORE HELP OR PICS...LET ME KNOW. i will go out there pull it out and take a few shots to help you out.. i know this is frustrating. i wanted to jab a flat head into my dash i was sooo mad.
PM ME if u want pics on this..i might do it anyway just incase this happens again
Old Mar 29, 2005 | 03:11 PM
kwc5811's Avatar
Just ordered mine, blue for the front and back and white for the map lights. Was real tempted to get the red but I wanted something bright and I didn't want my tC to look like a submarine.
Old Mar 29, 2005 | 07:00 PM
LucidBD's Avatar
blue and white looks great. i should have pics of taking out the grey control panel cover tonight
Old Mar 29, 2005 | 07:14 PM
bballplayer0968's Avatar
sry for intruding but would this work on the box too cause this was like the coolest idea ever
Old Mar 29, 2005 | 08:21 PM
LucidBD's Avatar
it depends on the bulbs. you can order all kinds of LED from them
Old Mar 31, 2005 | 04:11 AM
SpdLmtNA's Avatar
very nice, any opinions on the ultra violet LEDs?
Old Mar 31, 2005 | 04:24 AM
LED-Maniac's Avatar
Do the LEDS fade in and out the same way as the incandescant ones do?
Old Mar 31, 2005 | 05:20 AM
TCAV8R's Avatar
Damn, I paid way too much for super white/blue regular bulbs. I would have rather had LED's for a lot less. Great write up. Thanks. Hey do they have one for that light in the hatch? I still havent changed that one. Oh yeah, the license plate bulbs are the same as the front dome lights. You can put some LED's there.
I will put these LED's in when my current bulbs burn out.
Sticky please.
Old Mar 31, 2005 | 05:26 AM
woodstock's Avatar
Hmm.. you trying to turn your car into a Spencer's?
Yep, they flicker a little but it still fades.
The best thing about the white lights is that they have somewhat of a blue tint; nothing too ricey, but very nice.
Old Mar 31, 2005 | 05:29 AM
TCAV8R's Avatar
Red! Thats awesome. I may have to get those. Red/Amber lighting is actually the best to use at night. Most aviation lighting applications use red/amber. Hmmm
Old Mar 31, 2005 | 12:38 PM
LucidBD's Avatar
the rear hatch light i havent been able to fit the LED from the rear dome in there just right yet. im looking for an alternate LED.
the lights do still fade in and out. the do flicker a little bit when you start the car and just barely noticable when you close the doors. still, looks great
Old Mar 31, 2005 | 11:48 PM
Caedel's Avatar
Excellent tutorial. Followed it word for word and it worked great. The SuperbrightLEDs site is very good too. Ordered Friday around 2AM and got the stuff today.
Old Apr 1, 2005 | 12:10 AM
LucidBD's Avatar
glad to know it worked perfectly for you.
anyone having trouble and still want pics of taking the control casing off? if u accidentally dropped the housing and bulb into the back of it.
Old Apr 1, 2005 | 04:08 AM
johnnyicesae's Avatar
Well i got mine today. Did the Front dome no problem. but waited til it got dark to do the back.(i was anxious) Well i think i might have popped the fuse. Anyone know if this fuse is under the dash and what size it is? I'm assuming 15A or 20A. I'm hoping work gets canceled tomorrow (phones are f'd up) and i can take care of this.
Old Apr 1, 2005 | 04:50 AM
TCAV8R's Avatar
Pics are always good. Plus if the whole housing needs to come off I would like to see how that is done. I may want to do the auto-dimming mirror and that will have to come off.
