Steering wheel vibration...
Old Dec 15, 2011 | 02:42 AM
awcforever's Avatar
Default Steering wheel vibration...
I haven't seen any sticky's or other posts like this, but my 05 tc has a weird spot in the steering column you can feel when you sit still its like play in that first knuckle, but I can't get rid of it. I tightened it as much as I felt comfortable, but you can still wiggle the joint and it creates an uncomfortable sort of knock or click in the steering wheel.
It is very suttle, but noticeable. At highway speeds, my steering wheel vibrates pretty rough. I guess to give you a mental picture. Try shaking your steering wheel back and forth a half inch at a time fast enough that its a vibration. I don't know if the issues are related, but my tires seem good, my tie rods are tight as a drum, and my wheel bearings and ball joints all seem to be solid.
Sorry for being so long winded. I am sure this is a lot to chew on.
Old Dec 15, 2011 | 03:10 AM
LED-Maniac's Avatar
Try having your wheels balanced on a high speed road surface simulating balancer?
Old Dec 15, 2011 | 03:14 AM
AcidDrop's Avatar
^x2
Old Dec 15, 2011 | 06:25 PM
fongyz's Avatar
"click" feel as you turn the steering wheel???.... bcuz i get the click feel and no vibration on the highway..... wth.
Old Dec 15, 2011 | 10:03 PM
mrexotica's Avatar
Steering wheel vibration usually means bent wheel.
Clunk when you turn probaly means something in the linkage.
Old Dec 15, 2011 | 10:28 PM
fongyz's Avatar
not a clunk, its an actual CLICK IN the steering wheel or steering wheel column, no noises outside of the vehicle.
Old Dec 16, 2011 | 05:16 AM
sciontc_mich's Avatar
^^ check the steering shaft, and the intermediate steering shaft. There was someone else on here that had that go bad on them. That could be the issue of the "weird spot" when steering. If that is vibrating, I'd get it checked before it disconnects (if that is the issue)..
but the click could also be the wire spool that is built into the steering wheel hub. It is what turns off the turn signals when you move the steering wheel away from straight on.
Old Dec 17, 2011 | 03:25 AM
tCjosh's Avatar
^^x2 on that and also like said before, get the wheels balanced as well
Old Mar 4, 2012 | 07:35 AM
mrjtang's Avatar
^x3. get the wheels balanced first since its cheaper.
Old Mar 12, 2012 | 06:58 AM
marcossolares's Avatar
Yea getting your wheels balanced and getting a alignment
CombatmedicR56
Nov 12, 2020 01:53 AM
fur_pig
Mar 20, 2020 04:28 PM
bootlgr
Jan 26, 2016 01:22 AM
FurionAlpha
Scion tC 1G ICE & Interior
Jan 12, 2015 08:25 PM
Beesh
Jan 9, 2015 06:30 PM
