help with Fuel return system
Old Dec 16, 2011 | 07:21 AM
kimbym05's Avatar
Angry help with Fuel return system
Im looking to get a fuel return system for my boosted tc,i know ptuning has one and dezod has one as well.anyone know which is better? Or if there a better one out there?or better solution like custom making a kit.
Old Dec 16, 2011 | 11:38 AM
BOOSTit06's Avatar
I have the Dezod fuel return system, A friend of mine has the Ptuning fuel return system. They both work flawlessly. Either one would be a good choice.
Old Dec 16, 2011 | 01:07 PM
paul_dezod's Avatar
Scionetics
KAD
We're offering 5% off of any online purchase over $100 through the end of the month. Food for thought.
http://www.dezod.com/pd-return-fuel-system-tc-05-10.cfm
Old Dec 16, 2011 | 01:22 PM
PeArLwHiTe07tC's Avatar
speaking of fuel return paul, does it come with a new sending unit or do u have to drill out the existing?
Old Dec 16, 2011 | 01:40 PM
BOOSTit06's Avatar
^^^you have to drill out your own bud. There is a pretty good DIY one here somewhere...I havent seen it for years though lol. Im sure if you talk to Paul he can get you on the right track
Old Dec 16, 2011 | 01:49 PM
yeah thats kinda what i figured. i found the diy on dezods site. the way it makes it seems, as if it comes with the sender too. no biggie, ill just buy another one.
Old Dec 16, 2011 | 01:51 PM
paul_dezod's Avatar
Scionetics
KAD
Older editions came with the sending unit. Newer ones don't because cost on them sky-rocketed...
Old Dec 16, 2011 | 04:37 PM
kimbym05's Avatar
I already have the walbro fuel pump i think i saw on your site that its like 70 dollars cheaper without it correct?
Old Dec 16, 2011 | 04:40 PM
kimbym05's Avatar
How much boost are you running with the kit boostit06?
Old Dec 16, 2011 | 04:48 PM
paul_dezod's Avatar
Scionetics
KAD
There is discount for removing the pump from the setup.
Old Dec 16, 2011 | 05:27 PM
BOOSTit06's Avatar
Im running 21 psi
Old Dec 16, 2011 | 06:49 PM
kimbym05's Avatar
Sweet im guessing ur built..im on stock motor oí wanna try and boost 11psi
Old Dec 17, 2011 | 12:08 AM
BOOSTit06's Avatar
Yep built motor. The fuel return system will really allow you to expand.
Old Dec 17, 2011 | 02:41 AM
crush02342002's Avatar
WORD!!!
consider this, on 550cc injectors and stock fuel system I maxed out the injectors at 12psi (iv done 14psi on stock fuel system however leaks screwed up airflow), now on the same exact turbo system along with a dezod return fuel system (using dw 300lph fuel pump) im able to boost 23psi on 550cc injectors @93psi peak fuel pressure.
upping fuel pressure is key to get the most from your injectors
Old Dec 17, 2011 | 03:26 PM
kimbym05's Avatar
Damn sick...i deff need one . plus im running ethanol so i need it even more lol.....i want one!!!!
Flyfishfreak
Jun 10, 2016 02:55 AM
carid
Mar 30, 2015 07:08 AM
spawnconnery
Dec 18, 2014 08:38 PM
eric_m
79
Mar 17, 2013 12:21 AM
DjFrOsT
14
Dec 23, 2003 01:58 AM
