Oil Plate Sandwich Adapter/oil cooler?
With the oil plate sandwich adapter you can run a oil pressure switch, but can you also run a oil cooler system threw the plate at the same time? Cause there's no room with the s/c to hook up at the head.
sounds like you want to run a cooler using 1/8th npt fittings....kinda peeing in the wind imo. oil cooler isnt needed for most street apps however i run one (I feel better having that when i hotlap) and the one I have has 1/2" fittings and lines. also the sandwich adapter Im using is built for using a cooler, it allows for larger fittings and lines to be used.
this is something similar to what iv been using..
http://www.summitracing.com/parts/BMM-70266/
this is close to the sandwich adapter im using in that it has a bypass built into it (dont remember the thread pitch or size though)
http://www.summitracing.com/parts/TRD-1322/
im not saying this is what you have to have but you really should run 1/2" lines and fittings versus 1/8th fittings and small lines.
