Exclusive Sponsored Sales site sponsors with special deals...
NonStopTuning's Amsoil Oil Change Super Pack!!!!
Old Jan 17, 2012 | 02:22 AM
NonStopTuning's Avatar
Default NonStopTuning's Amsoil Oil Change Super Pack!!!!
NonStopTuning is proud to announce the Amsoil Oil Change Super Pack!
Changing your oil every 3,000 miles can be a hassle and easy to forget. That is why Amsoil has created a super synthetic blend that allows you to run a full year, or up to 20,000 MILES on a single oil change!
The NST Amsoil Super Pack includes the following:
- 5 Quarts of AMSOIL's super synthetic blend oil
- 1 AMSOIL super synthetic oil fiter
- 1 AMSOIL FLUSH KIT: allows user to flush their system before running the new AMSOIL blend to help better protect your engine and remove previous grime and build up.
The FULL NST Amsoil Super Pack runs you a total of only $85.00
NST AMSOIL SUPER PACK - (LOCAL PICK UP in HOUSTON) $85.00
NST AMSOIL SUPER PACK - + Shipping = $85.00 + $15.00 = $100.00 SHIPPED in the USA
Your standard oil change every 3,000 miles for 20,000 miles easily adds up to $200.00+ in parts.
That's a savings of over $125.00!!!
Feel Free to give us a call at 281-917-0221 to place your order, or for more information!!!!
Below you can get more vital information about the AMSOIL BRAND:
AMSOIL 100% Synthetic Motor Oil (ASL) delivers extraordinary lubrication in all types of automotive gasoline engines. By combining the industry-premier synthetic technology with AMSOIL premium additives, AMSOIL ASL exceeds the higher performance demands of modern engines. It withstands the stress of higher horsepower, higher heat and complicated emission control systems. AMSOIL Synthetic Motor Oil is engineered to outperform competitive conventional and synthetic motor oils. It delivers long-lasting performance and protection.
AMSOIL, the leader in automotive synthetic lubrication, produced the world’s first API qualified synthetic motor oil in 1972. Trust the extensive experience of AMSOIL The First in Synthetics® to do the best job protecting your engine.
Extends Drain Intervals
AMSOIL Synthetic Motor Oil can extend drain intervals far beyond those recommended for conventional oils. Its unique synthetic formulation and long-drain additive system are very stable, resisting oxidation and neutralizing acids. AMSOIL 5W-30 Motor Oil is designed to deliver the best possible engine protection, cleanliness and performance over extended drain intervals, reducing vehicle maintenance and waste oil disposal costs.
Maximizes Fuel Economy
AMSOIL Synthetic Motor Oil is designed to maximize energy efficiency for improved fuel economy. Unlike conventional oils, its uniform molecular structure helps it flow more freely and reduce friction between metal surfaces. Anti-friction additives are included to further improve energy efficiency.
Reduces Engine Wear
AMSOIL Synthetic Motor Oil provides outstanding anti-wear protection. It has excellent viscosity film strength to separate metal surfaces and robust anti-wear additives to further reduce wear in metal-to-metal contact regions for improved engine life.
Reduces Oil Consumption and Emissions
Volatility (burn-off) occurs when oil gets hot, causing high oil consumption and emissions. AMSOIL Synthetic 5W-30 Motor Oil has the lowest volatility rate of the oils tested, making it the best at controlling volatility-related oil consumption and emissions (see chart below).
Excels in Extreme Temperatures
AMSOIL Synthetic 5W-30 Motor Oil resists thermal (heat) breakdown better than conventional oils. It is heavily fortified with detergent and dispersant additives to prevent sludge deposits and keep engines clean. And unlike conventional oils, AMSOIL 5W-30 Motor Oil contains no wax. It stays fluid down to -58°F for improved cold temperature oil flow, reduced bearing wear and easier starting (see chart).
AMSOIL has a documented history of innovation and leadership:
First to develop an API-rated 100 percent synthetic motor oil.
First to introduce “extended drain intervals” with a 25,000-mile/1-year drain interval.
First U.S. company to utilize NOACK volatility test as standard of performance excellence.
First to produce synthetic oils for diesel, racing, turbo, and marine engines.
First to introduce synthetic oils that legitimately contribute to improving fuel efficiency.
First to manufacture synthetic gear lube for automotive use.
First to manufacture a 100:1 pre-mix synthetic 2-cycle oil.
First to manufacture a synthetic automatic transmission fluid for automotive use.
A few frequently asked questions regarding AMSOIL products:
What are AMSOIL synthetic motor oils?
AMSOIL Synthetic Lubricants are fuel efficient, extended life lubricants manufactured from select synthetic base stocks and special purpose additives. These lubricants provide improved overall performance characteristics when compared to conventional petroleum oils.
Whats types of synthetic base oil fluids does AMSOIL use?
As the developer of the world’s first API qualified synthetic motor oil in 1972, AMSOIL has gained more experience than any other oil company in formulating automotive synthetic lubricants. It is this extensive experience that provides the ability to maximize product performance through use of a full range of high-performance synthetic base oils, most notably polyalphaolefin (PAO). AMSOIL views synthetic base oils the same as it views additives, with each having its own set of unique properties. AMSOIL engineers its lubricants with the synthetic base oil or combination of base oils best suited to a specific lubricant’s application demands (gasoline, diesel, racing, transmission, gear, extended drain, extreme temperature, etc.).
AMSOIL INC. maintains an unwavering commitment to provide products that outperform the competition and deliver maximum benefits to all AMSOIL customers. Performance is the bottom line.
Can AMSOIL motor oils be used in any engine?
AMSOIL Motor Oils may be used in any mechanically sound gasoline or diesel fueled engine. Basically, that means they are excellent for use in any vehicle’s engine.
Will AMSOIL motor oils void the warranty of a new vehicle?
Absolutely not! Manufacturers’ warranties are based upon the use of oils meeting specific API Service Classifications, for example, SJ/CF. (AMSOIL lubricants meet the current API Service requirements and, thus, are perfectly suited for use in any new vehicle without affecting the validity of the new vehicle warranty.)
In addition, Congress in 1975 enacted the federal Magnuson-Moss Act to regulate written consumer product warranties. An examination of the law reveals warranties remain intact when AMSOIL Synthetic Lubricants are used. Click here for the full details.
Why are AMSOIL motor oils capable of extended drain intervals?
AMSOIL Synthetic Motor Oils are highly resistant to the destructive effects of heat, and do not break down like petroleum oils. This means that AMSOIL Motor Oils can provide much longer drain intervals than conventional lubricants.
Is there a recommended procedure for switching to AMSOIL motor oils?
There are no special requirements; however, in older vehicles or those with high mileage, it may be advisable to use AMSOIL Engine Flush first. This will ensure that the engine is clean and free of any accumulated contaminants which might have an effect on the service life of AMSOIL Motor Oils. In all cases, it is good judgement to install a new AMSOIL Absolute Efficiency Oil Filter (EaO) every time you change oil.
Please contact us at NST, Monday through Friday, to discuss the AMSOIL option that best suits your needs, and to schedule an appointment to stop by for a switch to the best lubricants money can buy!
CODY @ NST
Old Jan 31, 2012 | 11:04 PM
NST has SCION tC Amsoil Kits IN STOCK and ready for immediate pick up or shipping. Please contact us if you're interested in only ONE oil change this year!
MIKE @ NST
Old Mar 13, 2012 | 02:56 PM
Tshock's Avatar
That's a great buy. But Amsoil's web page calls for a 0w-20
http://www.amsoil.com/mygarage/vehic...010+SCION+TC+4
Old Apr 9, 2012 | 08:16 PM
NST can include ANY blend you'd like!
MIKE @ NST
voodoo2crue
Mar 18, 2015 01:30 AM
mischadoll
Mar 9, 2015 05:48 AM
cid_mcdp
Jan 5, 2015 02:45 PM
scionman2003
19
Feb 26, 2004 02:55 AM
BlueBox
22
Nov 7, 2003 08:18 PM
