5th Gear slip out, ANSWERS!!!!
Old Jan 18, 2012 | 03:12 PM
artimis6's Avatar
Default 5th Gear slip out, ANSWERS!!!!
I have seen lot of members post that while cruising in 5th gear it disengages into neutral. It only happens in 5th gear. Members always say they are going to dig into the problem but never post after they have figured out the problem. If anyone out there has had this happen and figured out what the problem was please respond. I would really appreciate it.
Old Jan 18, 2012 | 04:04 PM
thendawg's Avatar
Its the collar on 5th gear. You can replace 5th while its on the car.
Old Jan 18, 2012 | 04:09 PM
artimis6's Avatar
Thanks thendawg, I can get to the collar by removing the shift cover on the center console correct?
Old Jan 18, 2012 | 04:14 PM
Syldrin's Avatar
....i don't quite what understand your question. but from how it sounds. no you cannot reach the tranny from the center console. you can reach what dawg is talkin about from the drive side of the car just remove the driver side axel then drop the driver side tranny mount then remove the black cover on the transmission case. it will be there.
Old Jan 18, 2012 | 04:22 PM
artimis6's Avatar
Thanks Syldrin, how hard is it to find a replacement collar?
Old Jan 18, 2012 | 04:33 PM
Syldrin's Avatar
easy if you have the funds avalible. you can source a junkyard tranny for about 300-400 or you can call a parts store or dealership to see if you can get the collar itself.
Old Jan 18, 2012 | 04:44 PM
artimis6's Avatar
Thanks let you know how it goes!
Old Jan 18, 2012 | 06:03 PM
thendawg's Avatar
Actually 5th gear is accessible within the pan/cover on the driver's side of the trans. Basically, drain the trans. Take the driver side tire off. Take off the plastic wheel well crap. Remove the black pan on the end of the trans (like 12 bolts), than you have access to the 5th gear assembly.
If you look at the manual transmission dissassembly Jester wrote, it shows you how to take apart 5th gear.
Old Jan 18, 2012 | 06:09 PM
artimis6's Avatar
I will definitely try this as soon as I find a replacement part. Thank you so much for your replies. Since my tc is no longer under warranty the dealer was going to charge me thousands to fix this problem. Thanks again.
Old Jan 18, 2012 | 07:57 PM
TCpete's Avatar
someone has posted a DIY on this forum for that 5th gear. i saw it a fews ago... or maybe it was cstc. ill try to find it for you.
Old Jan 19, 2012 | 01:25 AM
artimis6's Avatar
Thanks tcpete, I would appreciate it.
Old Jan 21, 2012 | 03:18 AM
ESEMRFOZZ13's Avatar
what's your location? i get dealer prices and corporate discounts at a number of places.
Old Jan 21, 2012 | 02:38 PM
artimis6's Avatar
I live in Cedar City, Utah. Quite a ways from you.
Old Jul 13, 2013 | 02:57 AM
alisha21z's Avatar
Where did you end up finding the part? I have been calling around a shopping around, and I cant find just the collar. I really don't want to buy a transmission for just one part....
WRX1316_TcVicent
Jul 22, 2021 06:06 PM
dbg326
Aug 28, 2015 05:18 PM
javio24
Aug 13, 2015 05:27 PM
TheRealShark
Scion tC 2G ICE & Interior
Aug 5, 2015 05:08 PM
