3rd gear shifting problems
Old Jan 21, 2012 | 05:10 AM
Toast_Burner's Avatar
Default 3rd gear shifting problems
So recently when I shift into 3rd gear sometimes I feel a light grinding. It seems to only happen when my car is cold and does not happen after my car is warmed up. I did some searching on this and have heard multiple things the most common being issues with the syncros. I am not to familiar with transmissions and was hoping to get input from you all.
Some other things I should note:
-car has 12500 miles
-I drive like a complete jackass and probably put A LOT more stress on my xb than most people
-months ago I seemed to have trouble shifting into 2nd gear. It usually would happen when launching (high rpms in 1st) but this problem stopped so I don't think about it.
-I was shifting through my gears while stoped and there is still a wee little grind sometimes when shifting into 3rd
-it is winter (____ gets below 30 degress)
-I have NST shift bushings, most importantly I need to make 110% sure that they are not the problem. I don't want the dealer telling me that shift bushings are the problem.
thats about all I can think of and I would appreciate any insight.
Old Jan 21, 2012 | 07:41 AM
Deltabravo03's Avatar
I have exactly the same problem as you but my 2ed gear..... Dos it only in the cold and when it warms up it stops doing it. Weird
Old Jan 21, 2012 | 03:06 PM
AAG's Avatar
AAG
DeepSouth Scions
Switch to Eneos MTF. If that doesnt fix the issue, your syncro is done.
Old Jan 21, 2012 | 03:31 PM
my06tc's Avatar
when the tranny is cold......the fluid isnt warmed up,reason why for a grind,is that there isnt enough lubercation metal to metal,some people have to shift slow when there car is cold...change your tranny fluid to eneos or something,so ill warm up quicker
Old Jan 21, 2012 | 05:02 PM
SamCarroll's Avatar
i have this issue in reverse. sometimes in second when the engine is cold. Just wont shift into it.
Old Jan 23, 2012 | 01:21 AM
TrevorS's Avatar
Wasn't much over 20F midday here and I noticed 2nd was just a little balky at first, though not bad and it isn't usually that way at all. Penzoil Synchromesh worked wonders in my Eclipse, wonder how it would do in the xB2?
Old Jan 23, 2012 | 01:45 AM
Zsanz's Avatar
my 3rd gear sync acts up when the tranny is cold.
80k miles, still under warrantee ill bring it in before the 100k mark
Old Jan 24, 2012 | 12:02 AM
TrevorS's Avatar
Temp was easily mid to high 30's today and 2nd was just fine. Guess it's just an oil issue at lower temps.
Old Jan 24, 2012 | 02:55 AM
VENisME's Avatar
If it doesn't go into gear right away put in neutral pump the clutch pedal a few times then try to put it in gear. Probably won't help with grinding though.
Old Jan 24, 2012 | 03:52 AM
TrevorS's Avatar
FWIW -- anytime you're overriding your synchros, you're hurting your transmission. If you care about cost and longevity, surely it's better to cooperate with your transmission than to force it ! I suggest limiting your shift angst to your transmission's comfort zone !
Old Oct 16, 2012 | 03:33 AM
Roller_Toaster's Avatar
My 3rd started to grind a bit...then I realized my clutch maser cylinder was going out.
I still shift into 3rd nice and slowly though.
Old Oct 17, 2012 | 03:06 PM
dasrider's Avatar
4th gear grind here. It's not going to get better so I just shift nice and smooth into 4th every time. '08 with 120k miles.
Old Oct 18, 2012 | 06:33 AM
TrevorS's Avatar
Old transmission fluid can definitely be a shift issue (had that problem with my high miles '90 Eclipse), so if you've racked up a few miles, by all means change it. However, number one is to be kind to your transmission. Look after your mechanics and it's less likely your wallet will hemorrhage.
2008ScionXbGold
11
Aug 15, 2016 10:50 PM
randode
127
Aug 19, 2004 03:26 AM
iglooxb
15
Jul 25, 2004 06:18 AM
scionaraxb
Nov 7, 2003 08:16 PM
sensez
Oct 18, 2003 03:34 PM
