2011-____ [ANT20]
Factory Warranty
Old Feb 9, 2012 | 09:57 PM
1293RS7's Avatar
Default Factory Warranty
OK, So I searched the tC2 forums and couldn't find anything about factory warranty and what will and what wont void it. So what will what and what won't? Intake? Coil-overs? Turbo? Exhaust? Looking at your car wrong?
Old Feb 9, 2012 | 10:27 PM
ProjectTC2's Avatar
Dependant upon which dealership you go to it will vary. Some dealerships, if a bird poops on your car then your warranty is voided. But some dealerships treat it as they should, that only a portion of your factory warranty is voided if you install an individual aftermarket piece to it. For example, if you install an intake and you get a MAF CEL, then they wont cover that...but if you install an intake and you get a ticking cam gear, then that's still covered
Old Feb 9, 2012 | 10:38 PM
1293RS7's Avatar
first off thanks for the reply, second whats a MAF CEL? I just dont want to have a problem if i throw on a intake and some coil overs and then dealership just turns me away. I already spend enough getting my car and I dont want to have to pay for something if it goes wrong because between my payment and insurance i dont have much money to throw around.
Old Feb 9, 2012 | 10:40 PM
WellesleyScion's Avatar
You probably wanna do some research before installing anything if you dont know what a MAF CEL is...
Old Feb 9, 2012 | 10:45 PM
KidJustin's Avatar
DaYUUM/Scion Evolution
Research research research...I've seen posted on this forum answers to ur q.
The answers might not be specific enough for u, but is enough info about the warranty that u can figure it out
Other sources....
Trdsparks.com
Scion.com and go to the warranty & maintenance manual
Or the warranty & maintenance manual from the car itself
1293RS7's Avatar
Originally Posted by WellesleyScion
You probably wanna do some research before installing anything if you don't know what a MAF CEL is...
Searched it....found it, i knew what those were just never seen them abbreviated, I've never posted in car forums before
Old Feb 9, 2012 | 10:47 PM
1293RS7's Avatar
Other sources....
Trdsparks.com
thanks KJ, ill have to dig deeper on here i guess and see what i can find, just wasn't having much luck with the search feature on the forums.
Old Feb 9, 2012 | 11:55 PM
ProjectTC2's Avatar
Yea the search on the forum can be such a pain in the butt to use. But just be aware, that if you mod your car and that mod causes a problem, they 100% WILL NOT cover the problem that it caused
Old Feb 9, 2012 | 11:58 PM
1293RS7's Avatar
that will prob keep me limited to just really simple bolt on stuff, so i dont get my self into too much trouble. guess that will force me to make payments on the car instead of buying stuff for it.
Old Feb 10, 2012 | 01:12 AM
JVERMETTE's Avatar
I have recently talked with Scion themselves and they have stated that if you have a tC2 any parts other than TRD will void your warranty. If you want to install an exhaust you are allowed to install a cat-back with out voiding your drivetrain warranty as long as you
do not remove or relocate the cat or take out the oxygen sensors. As for the CAI you cannot put an intake on other than TRD because you have to remove and reinstall the MAF sensor. If you do this it will void your warranty. As far as turboing they stated that if you turbo your Scion that you will void all engine warranty's and risk voiding all others. You can believe this information or not, but this is what they stated to me.
I have checked with multiple dealerships and they have all stated this as well, as well as a few ASE certified mechanics. I have also asked about Descendant intake or parts and scion stated that if you don't want your warranty's then go ahead and do what you want. I don't know about you but I have a 2012 Scion tC and am looking to keep my warranty's. So I am going to install all TRD stuff. Just like the 2012 GReddy Scion tC.
Old Feb 10, 2012 | 02:11 AM
Erager09's Avatar
But the dealership has to show that the modification caused or contributed to the failure of whatever part your trying to get fixed. My Injen CAI didn't void my engines warranty...maybe the MAF... but not the engine. But I'm sure the dealership will fight you tooth
and nail before they replace/fix whatever problem comes up. So TRD is probably a safe bet. But even my dealership gave me ____ a while back because I had a syncro go bad and I didn't bring my car in for regular service. I changed it more often on my own.
They fixed the issue but didn't replace the trans. So they try and screw you either way. At least TRD wont give them a way out of fixing a problem.
Sent from my DROID3 using Tapatalk
Old Feb 10, 2012 | 03:08 AM
fun173's Avatar
Originally Posted by JVERMETTE
I have recently talked with scion themselves and they have stated that if you have a tc2 any parts other than TRD will void your warranty. If you want to install an exhaust you are allowed to install a cat-back with out voiding your drivetrain warranty as long as you do not remove or relovate the cat or take out the oxygen sensors. As for the CAI you cannot put an intake on other than TRD because you have to remove and reinstall the MAF sensor. If you do this it will void your warranty. As far as turboing they stated that if you turbo your scion that you will void all engine warranty's and risk voiding all others. You can believe this information or not, but this is what they stated to me. I have checked with multiple dealerships and they have all stated this as well, as well as a few ASE certified mechanics. I have also asked about Descendant intake or parts and scion stated that if you dont want your warranty's then go ahead and do what you want. I don't know about you but I have a 2012 scion tc and am looking to keep my warranty's. So I am going to install all TRD stuff. Just like the 2012 GREDDY Scion TC.
So would my intake void the whole engine warranty or just if the MAF goes bad. I couldn't give 2 craps about the MAF going as I would just buy a new one but the engine warranty is a different story.
Old Feb 10, 2012 | 03:14 AM
Erager09's Avatar
Look up the magnuson moss act which states that a warranty can't be voided by modifications that didn't cause the problem. (Ex. Aftermarket radio voiding your whole electronic warranty) I mean if you install a cai and then blow your engine and they find sand or debris in your cylinder maybe because the cai may not have filtered to stock specs. But if you spin a bearing or your alternator goes bad they can't blame the cai ya know?
I can't tell you yes/no 100% bc im just another driver and all my warranties are fubar at this point. (Turbo/led swap/etc) maybe my corrosion protection is still good...doubtful tho.
Old Feb 10, 2012 | 03:37 AM
fun173's Avatar
Alright, thanks. I wonder if the dealer writes down what modified parts you have if any when you go in for service.
Old Feb 10, 2012 | 03:39 AM
Erager09's Avatar
Yes they will...my service papers for the trans list the intake/exhaust and led swap
Old Feb 10, 2012 | 03:41 AM
fun173's Avatar
Good to know. (contemplates swapping intake back to stock for service) :D
Old Feb 10, 2012 | 03:51 AM
dstock1088's Avatar
TRD is the best anyway. Stick with OEM performance parts. They are designed to work with your car perfectly.
Old Feb 10, 2012 | 05:49 AM
1293RS7's Avatar
Thanks for all the responses guys, looks like i will lean toward TRD more than any thing now just to play it safe. Its good to hear what other people have ran into when taking the car into service with third party after market parts on it.
Old Feb 10, 2012 | 02:11 PM
PEwilly9's Avatar
u have to ask yourself a question - do you want to be limited in your "mods" or do you want to be unique and free. If your going to mod outside of the OEM market just know how to paly the game and do what you can to NOT f*** up your ride. Im cautious, but the attraction to theses aftermarket modifications became way to much to handle! lol
Old Feb 10, 2012 | 02:25 PM
ROCKLANDTOYOTA's Avatar
UNLESS Scion rep that trolls on here says different I call BS......
