Can someone help me replace SC shaft bearings?
Old Feb 12, 2012 | 09:56 PM
gqdabien's Avatar
Default Can someone help me replace SC shaft bearings?
Hello I'm looking to see if someone can help me replace the shaft side bearings. I can take it off the car.
I don't know what type spec bearings I should buy, of I buy these ahead of time to make things easier that's possible also. Please reply or pm me if you can help a scion brotha out.
Thanks!!!
Old Feb 14, 2012 | 12:32 AM
gqdabien's Avatar
I was able to look up the bearing and shaft seal information:
TIMKEN # 222540 seal
6205-2RS (2) radial ball bearings
Anybody have tips / pictures on getting this stuff out of the stock shaft?
Old Jul 17, 2013 | 01:34 AM
PrettyniceB's Avatar
what ended up happening with your bearings..... who fixed it?
Old Jul 17, 2013 | 03:58 PM
Sleeper_TC's Avatar
if you can, try to get the same kind of bearing (SEALED) but is rated at a higher rpm cause its alot better...
i had the same situation like almost 2 months ago where i found a clod of dirt inside the housing on my pulley side causing it to eat up my shaft and bearings..
just hope that its jus your bearings and not your shaft too. the shaft is the one that will bite you in the tush.
Old Jul 18, 2013 | 01:09 PM
SoccerBoy_AP's Avatar
If you take the time to get those bearings replaced, do them a favor and install the grease fitting so you can keep them lubricated and help them last longer.
Old Jul 19, 2013 | 05:08 AM
Sleeper_TC's Avatar
the bearings that i got came with grease fittings inside them, i got my bearings from a bearing company
fur_pig
Mar 20, 2020 04:28 PM
tato63
Scion tC 2G Wheel & Tire
9
Sep 30, 2015 09:55 PM
blh72
Scion xD Wheel & Tire
Feb 2, 2015 12:36 AM
torranosaurus
Jan 28, 2015 04:53 AM
stankubrick
Oct 16, 2003 10:38 AM
