View Full Version : Quieting wheelwells?
mjdukehart2
03-28-2005, 10:26 AM
Any suggestions for quieting the wheelwells. THey are louder than all hell when the roadway is wet.
TheIcon
03-28-2005, 11:32 AM
Turn the radio up :) :)
Fujiz_xb
03-28-2005, 12:58 PM
or get an intake.. you wont complain about that.
Mooneyzs
03-28-2005, 01:23 PM
How about Spraying some undercoating or sound deadner on the wheel wells. Another option would be to use one of those do it yourself Bed liner stuff on it. like Herculiner. I did the Bed of my 71 El Camino and it looks great. I also think it would help Kill Road noise.
mjdukehart2
03-28-2005, 01:25 PM
Is it a diy sort of thing that you can pick up at the autoparts store?
pdrizzle
03-28-2005, 02:16 PM
I wouldn't spray bed liner, it is probably very heavy due to its durability. I saw on here the other day, someone had sprayed their trunk area with a sound deadening material (I can't find it now). I did a quick search and found this thread, though:
http://www.scionlife.com/forums/viewtopic.php?t=45593&postdays=0&postorder=asc&highlight=sound+trunk&start=0
It's a sound deadening comparison.
Max
03-28-2005, 02:52 PM
I put some eDead down on the floor, helped out a ton with the loud exhaust at 3k rpm. I plan on doing the same to the inner wheel wells soon.
http://scionlife.com/forums/viewtopic.php?t=54184
dougalast
03-28-2005, 02:58 PM
For some reason i opted for the factory toyo-guard package - it includrd undercoating. I don't get much road noise compared to other boxes
Mooneyzs
03-28-2005, 03:05 PM
Yes it is a diy sort of thing. and you can pick it up at most autoparts stores. I have seen that different autoparts stores carry different brads. I would try some of the sprayable undercoating first and then go from there. It would be the least expensive option.
MuNkY
03-28-2005, 03:59 PM
On the inside of your wheelwell in under the hood, if you put some dynamat, it will lower road noise by a lot, same with the back.
