* xB2 Gauge Cluster LED Conversion/Swap Installation Guide
Old 02-25-2012, 08:15 PM
LEDmod's Avatar
Default * xB2 Gauge Cluster LED Conversion/Swap Installation Guide
Scion xB2 Gauge Cluster LED Conversion/Swap Installation Guide
by LEDmod.com
For 2008-2010 models, also 2011-up models compatiable
** NOTE : This isn't for beginner, so if you aren't sure you can do this then, please seek professional help.
We also offer installation for Local and Out of state customers
Local installation service available (Follow the link for more information)
- Southern California
- Las Vegas
- New York (currently not available)
- For out of state customers, please e-mail me for information Sean@LEDmod.com
Here is a step by step guide for LED Conversion/Swap
Things you'll need (Mostly available at RadioShack)
- Fine point Pencil Soldering Iron (Recommend 15-30 watt)
- Solder : Prefer silver-bearing solder or rosin core solder (Thinner the better, easier to work with)
- Soldering accesories
- Philips screw driver
- Surface mount LED (LED Conversion/Swap Kit available from here LEDmod.com)
* NOTE : Stock gauge face will only work with Red LED
- Stock gauge face has orange pigment that prevents other colors to pass through
- Custom gauge face from LEDmod.com will allow other colors to pass through properly and prevents light bleeding through
- You can check out custom gauge face from here
LEDmod is offline
LEDmod's Avatar
Scion xB2 LED Conversion/Swap Installed Sample pictures
(All the sample picture below has custom gauge face)
LEDmod is offline
Old 02-25-2012, 09:25 PM
r2d2michael's Avatar
Very well done write up ! I will use this when I convert my lights!
r2d2michael is offline
Old 02-26-2012, 12:15 AM
LEDmod's Avatar
Thanks, been meaning to make it for long time...
LEDmod is offline
Old 02-29-2012, 03:27 PM
P1MP5QU4R3D's Avatar
I will deff have to find someone to do this for me........
P1MP5QU4R3D is offline
Old 02-29-2012, 07:55 PM
I would like to do a full led and swap from a 09 to 11+ gauge cluster., wonder if it’s pretty close to a direct swap.
Old 02-29-2012, 10:19 PM
LEDmod's Avatar
Yes but odometer is stored inside the gauge cluster. So you'll get different miles from the spare gauge cluster.
It's illegal to have different miles.
So you'll have to get it reprogram to match your stock miles to be legal.
We offer reprogramming to match your stock miles.
LEDmod is offline
Old 02-29-2012, 10:30 PM
dodong27's Avatar
That's awesome!
dodong27 is offline
Old 02-29-2012, 11:32 PM
Wait so are you saying that it is a direct swap? Plug and play? How much would the reprogram be? I know in the Honda world lots of people run around with different gauge clusters. I did in my crx lol
Old 03-01-2012, 03:36 AM
VENisME's Avatar
Me too.
VENisME is offline
Old 03-01-2012, 05:35 PM
LEDmod's Avatar
Second generation xB is plug and play.. since wiring harness is same
We charge $80 to transfer the odometer(your original miles)
You'll have to provide your stock gauge cluster and spare gauge cluster
That way it will keep it legal to retain your miles.
Yes, you can swap out wither different gauge cluster, but if you have yearly inspection or smog check, you will have different miles (if DMV keep a record of it)
Also for when you are selling your car, it will be a fraud to sell the car with different odometer...
So we do this professionally, so we follow the rules and regulatation..
If you don't care about the odometer, then yes you can just simply swap them out....
LEDmod is offline
Old 03-01-2012, 07:32 PM
Has this been done before? I would problem send you the 08-10 gauge cluster and an 11+. Switch over the miles and do a led swap at the same time. Now I just have to find an 11+ cluster on the cheap.
Old 03-02-2012, 12:26 AM
flyingemu05's Avatar
^yeah its been done before. theres an '08 i think on clubxb with an '11 gauge cluster.
flyingemu05 is offline
Old 03-02-2012, 05:11 PM
LEDmod's Avatar
Used spare gauge cluster is still on the expensive side.. since not many out there...
LEDmod is offline
Old 04-17-2012, 05:34 AM
LEDmod's Avatar
Check out the package deal if you wanted professional installation service through us..
LEDmod is offline
Old 05-05-2012, 07:05 PM
LEDmod's Avatar
Bump
LEDmod is offline
Old 05-07-2012, 01:25 AM
KaneoheKoa's Avatar
Great writeup, now I can go ahead and rewire the multifunction switch and relocate it to the shifter!
KaneoheKoa is offline
Old 05-08-2012, 08:28 PM
LEDmod's Avatar
Bump
LEDmod is offline
Old 02-12-2013, 02:30 AM
LEDmod's Avatar
bump
LEDmod is offline
Old 02-24-2013, 08:50 PM
Hayes's Avatar
For curiosities sake, what do you charge if I send you the unit?
Hayes is offline
Quick Reply: * xB2 Gauge Cluster LED Conversion/Swap Installation Guide
