sway bar install. Did you need an alignment??
Old Feb 12, 2004 | 04:14 AM
Road_Racin's Avatar
Default sway bar install. Did you need an alignment??
I did... :?:
Old Feb 12, 2004 | 05:23 AM
Guest
Guest
Posts: n/a
ok, you needed an alignment after the swaybar install?? Why what was messed up? You are not supposed to remove any alignment adjustments for the install. Just the subframe.
Old Feb 12, 2004 | 05:27 AM
squirrel's Avatar
when I installed the Hotchkis bars on my Matrix, I needed a front end alignement. But when I did the xB, I was a bit more careful and didn't need one. It just depends on how much you move the subframe around while doing the install.
Old Feb 12, 2004 | 05:32 AM
Guest
Guest
Posts: n/a
also, after the alignment was done , did they tell you what was adjusted?
Old Feb 12, 2004 | 05:34 AM
HotBox's Avatar
stylis would you mind writing me a list of what to ask just to make sure everything is *british accent* right and proper after the install
Old Feb 12, 2004 | 05:53 PM
Guest
Guest
Posts: n/a
well, you need to make sure all the bolts are back in!! MIKEY is here and we found a bolt missing going to the chasis, he is going back to the dealer right now to have them install a new one. :D Scion central does it again!!! :D
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
gedster314
Regional - Pacific South
Feb 19, 2021 07:51 PM
rvascion
Nov 12, 2020 03:23 AM
SloTC1
Aug 16, 2018 02:45 PM
babyfac3pn01
Oct 19, 2015 07:24 AM
