Got bored at work a few weeks back
Old Mar 19, 2012 | 07:50 AM
RedDragons's Avatar
Default Got bored at work a few weeks back
So I was bored at work a few weeks back and had some extra parts lying around so I got crafty and made this.
I drilled in a pin switch low behind the right side of the glove box and mounted 5 or 6 LEDs on a sheet of ABS I cut and heated up and bent. Shot it in with 4 self tapping screws and wired it through a relay off of the + Illumination wire at the radio and are activated through a - trigger on a relay. Works great and only took me about 30 minutes to put together and install.
Old Mar 19, 2012 | 08:01 AM
xseveredveganx's Avatar
Utah Scions
Looks good! Certainly something our cars need!
Good job!
Old Mar 19, 2012 | 01:38 PM
11ScionXb's Avatar
Looks good!
Old Mar 19, 2012 | 11:18 PM
TrevorS's Avatar
I'm completely out of mods for both my vehicles, and glove box illumination is a good idea, something to consider -- thanks !
Old Mar 20, 2012 | 05:47 AM
Goodtimes197750's Avatar
Great idea
Old Mar 20, 2012 | 07:34 PM
2011xb4me's Avatar
looks bada$$.
Old Mar 22, 2012 | 08:22 AM
RedDragons's Avatar
Thanks guys, I had a pic of what it looked like when mounted but I cant find it. It makes a huge difference at night. I really like it. Even though I rarely drive at night and get in my glove box even less it was still fun and kept me entertained for the end of my shift. I have been thinking about doing the LEDs in the cupholders next.
Old Mar 22, 2012 | 09:21 AM
KaneoheKoa's Avatar
I remember by dad's 1960 Chevy wagon having a glove box light. Wonder why car makers think we don't need them now?
But they do beg the eternal question: does the light go out when you close the glovebox? How would you know?
Old Mar 22, 2012 | 10:25 PM
RedDragons's Avatar
It does because I installed a pin switch and its mounted low enough that once you start to close it before its actually shut it turns off.
Old Apr 19, 2012 | 03:48 PM
xb2owner's Avatar
I used one of those "as seen on tv" lights that turn on when the magnet is pulled away.
Amazon Amazon
I used something similar to this. It works very well.
Old Apr 20, 2012 | 12:22 AM
TrevorS's Avatar
Was just looking behind my glove-box. I'm guessing you mounted the LED panel between the two metal braces above the box, but where exactly did you mount the pin switch? Seems like it would have to have a bracket to the right of the air filter and anchored to the tubular steel brace that extends from side-to-side under the dash.
Old Apr 21, 2012 | 02:16 AM
TrevorS's Avatar
Took another look and decided to give it a go with a piece of angle aluminum, a strip of LED's, and a pin switch. I've ordered the strip and switch and while awaiting delivery, I'll take a look at wiring options.
Old Apr 27, 2012 | 07:25 AM
1SCIKXB's Avatar
I likely...next on my mod list
cid_mcdp
Jan 5, 2015 02:45 PM
TheTripleC
Jan 4, 2015 06:46 PM
fluxingnation
Dec 26, 2014 04:28 PM
k1114
Nov 30, 2014 01:40 AM
2fixA
Sep 29, 2003 08:36 AM
