Correct maf readings?
Hey guys could use some help figuring out if my MAf is going bad pls look at the scale at 4000 rpm it seems to max around 220.... And go flat line is this normal?
Sent from my PG86100 using Tapatalk
i don't know how to read your chart, but my maf did break down on me on my xA. engine light is on, car doesn't suck in enough air, it chokes, it turns off by itself if you leave it on without tapping the gas. hope this info helps in some way haha.
Seems to me that you either need a larger MAF pipe to extend the oem MAS' limits and a re-tune or a MAP sensor that can take over once the MAS volume is exceeded. Good luck.
FWIW I looked through some other scan logs and it appears that my peak MAF is ~200gps at only 6 psi boost. The slow sampling rate of the scan tool accounts for it only reading 170gps on that one log. It's good to know that my MAS is almost maxed out. No point in even trying to add any boost without some major setup changes.
Good luck with everything.
evolving_machine
10-21-2023 01:16 PM
Bakoscion46x
01-19-2015 02:39 AM
cid_mcdp
01-05-2015 02:45 PM
