Water pump leaking
Old Apr 2, 2012 | 08:08 PM
DJrepresent's Avatar
Default Water pump leaking
Hi,
I took my car to my Toyota dealership and they pointed out that my water pump is leaking as it was making a strange noise and opening the hood revealed a white streak on its underside.
Is it expensive to fix? Will it result in my coolant levels decreasing, and if so, should I be replenishing my coolant until I can get the pump replaced?
Thx.
Old Apr 3, 2012 | 02:00 AM
TrevorS's Avatar
OK, so that's a drag ! Take a read through this thread, may well help.
https://www.scionlife.com/forums/sho...d.php?t=170350
Depending on your warranty status, replacement might be free! Cost of a new pump isn't too bad, but the installation billing is a bit tough !
Old Apr 3, 2012 | 05:58 PM
Installation cost I'm not too worried about since my best friend's father runs a body shop and can probably get me his price on a replacement pump.
Old Apr 4, 2012 | 02:36 AM
TrevorS's Avatar
If you have someone who can give you discounts on parts and labor, then that may be the best bet. Still, read the thread I linked and make note of the current part number and others observations -- may be helpful .
Old Apr 6, 2012 | 04:41 PM
If I can't get it repaired right away, I wanted to ask, should I keep replenishing the coolant?
Old Apr 6, 2012 | 08:27 PM
TrevorS's Avatar
Are you asking if it's OK for the coolant level to go below the low mark -- I'm thinking you already know the answer to that. Still, it's your car !
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
Btp907
Sep 11, 2015 11:46 PM
