Uneven coilovers?
Old Apr 8, 2012 | 09:01 AM
raymondsayz's Avatar
Default Uneven coilovers?
Hello SL! This might seem like a stupid question but i dont know what to do haha. So i running on tanabe sustec pro s-0c coilovers. The rears seem to be off. I dropped the rear left and right coils to the exact same position. However, the height of the car came out different. There is about a one inch different in height.
The image will explain my problem. Thank you!
If this is an obvious problem and answer please respectful in your response. im new at this lol
Old Apr 8, 2012 | 09:13 AM
dropzone's Avatar
How long, or actually how many miles have been put on the suspension. If you're the only one in the car this whole time that's possibly why it's settled more to the driver side, and I think it's also the side with extra weight of the transmission(someone correct if I'm wrong on this).
Old Apr 8, 2012 | 09:28 AM
ive had it for about 10k miles now. but i just lowered it today. would all that really make a one inch difference though? the fronts are perfectly even.
Old Apr 8, 2012 | 10:51 PM
c500129's Avatar
coilovers are adjustable. find out your ideal height. measure from the center of the wheel to the fender. and adjust all of them to be that same measurement. then your done
Old Apr 8, 2012 | 11:14 PM
Carlanga's Avatar
I had the same ordeal, the left was lower than the right even when I had the tein s tech. Now I have HKS RS coilovers and I have the left adjusted past halfway up the threads and the right is almost all the way down just to keep both sides symmetrical. Downside is that the left is preloaded.
Old Apr 8, 2012 | 11:16 PM
Carlanga's Avatar
You could try and find someone with scales and balance the suspension with close to ideal height.
Old Apr 9, 2012 | 01:16 AM
mrexotica's Avatar
Did you properly assemble the coil overs? Did you double-check?
Old Apr 9, 2012 | 07:57 AM
Very True! but then the coils will be not be adjusted to the same threads. It just seems wrong to that haha. Is is going to be my temporary fix though. Thanks!
Old Apr 9, 2012 | 07:58 AM
Hmmm i wonder why its doing that =/
Old Apr 9, 2012 | 07:59 AM
yea i might have to if i cant figure it out. Thanks!
Old Apr 9, 2012 | 08:01 AM
the coils came assembled and i didnt change anything before install. my guess is that my install on the right side was bad. i dont know haha. thanks for your input.
Old Apr 9, 2012 | 12:51 PM
mrexotica's Avatar
You're welcome.
Before you spend the money on corner-weighting, be absolutely sure they are assembled and installed correctly. Then, get a reputable alignment. Cornerweight is important if you are racing.
When I built and installed my Koni/Ground Controls, I read the directions, made sure they were exactly the same before I installed them, read the directions again, installed them, adjusted them in pairs ( fronts or rears ).
Whenever I'm not absolutely sure I know what I'm doing, like when I had to disassemble the struts for the Koni inserts, I take it to a local shop that I trust. Better safe than sorry. Besides, I spent a little money there, display their decals at the races, now they give me a nice discount, after I proved myself( but that's another post...)
Old Apr 11, 2012 | 01:19 PM
Spicy_McHaggiz's Avatar
There's a reason why people with coils should corner balance. Not only will you actually get a handling improvement from it, but it will even out the car nicely.
greytc
Oct 26, 2015 07:53 PM
Darrenohooligan
Sep 26, 2015 07:21 AM
rmz489
Sep 16, 2015 08:19 PM
ScionDP
Sep 8, 2015 02:17 AM
