View Full Version : Anyone make stiffer motor mounts/motor mount bushings?
jackmott
02-12-2004, 07:32 PM
I've seen this mod greatly reduce wheel hop in other front wheel drive cars.
dinkjs
02-12-2004, 07:39 PM
I dont think so....but go check out enery suspensions website......
But my personal opinion I feel heavy duty motor mounts are a waste of time unless your making enough power were wheel hop becomes a problem very frequently....for these cars I feel they arent worth the time.....maybe for the tC though
jackmott
02-12-2004, 07:41 PM
I thought so too, but I was getting wheel hop all over the place since I got my scion, of courses, its been raining out. But yeah, first gear is so agressive it can spin those lil tires.
But its such a cheap mod (usually) and easy to install with nearly no downside except a little noise.
TheRedBox
02-12-2004, 08:00 PM
yenno you can do it the cheap way and insert polyethelene (plastic cutting board) in the motor mounts. A lot of DSM guys do this. Or you can add a layer or window weld, widow weld.. dont remember what its called, on top of the mounts. That way takes longer, but it helps just as much.
dinkjs
02-12-2004, 09:21 PM
Sorry I own a DSM.....and I am a frequent person on my cars website and I have never heard of using plastic cutting board....nor anyone else used it
TheRedBox
02-12-2004, 10:05 PM
YOU NEVER HEARD OF THAT AND YOU OWN A DSM????? DUDE WHERE HAVE YOU BEEN??? YOU NEVER USED THE VFAQ?!?!?! You are not a DSMer if you dont use the VFAQ.
http://vfaq.com/index-main.html
under engines, scroll to the bottom.
OR heres a direct link
http://www.geocities.com/gulfblvd/mountinserts.htm
I don't know if I should give you a :oops: , a :cry: , a :shock: , a :? , or a :roll: for being a DSMers that didn't know that.
dinkjs
02-12-2004, 11:22 PM
just because its on there doesnt mean people do it
TheRedBox
02-12-2004, 11:25 PM
:roll:
There's a whole bunch of stuff on there, from turbo swap guides, to clutch jobs even wiring up your SAFC....
:roll:
HemanC
02-13-2004, 12:02 AM
I've seen Weapon-R has something like this one. Contact Leo for a more accurate info :)
abbfanuc
02-13-2004, 12:10 AM
I saw a prototype of weapon-r. Scionmag had one at Exposed with a new double tube intake.
scionxb04
02-13-2004, 12:44 AM
i have the engery suspension engine mounts in my 2k civic si...along with allota of other people i know who drag at sac speedway....either u gotta use the inserts or get real mounts.....the inserts helped with launch hookup immensly.....if u can find the mount inserts for the scion let me know where.....
02-15-2004, 06:40 AM
I will check the mounts to see if they are the same as a corolla. Sometimes toyota uses the same design to save money and I think I saw the inserts for a corolla on scion tuner magazine. :D
scionxb04
02-16-2004, 07:18 AM
let me know what u find....
