WTB 2008 xb engine
Old May 11, 2012 | 01:00 AM
KoolBox's Avatar
Default WTB 2008 xb engine
some body help me to get an engine for my 2008 xb,call me @ 561-389-8738,thanks.
Old May 11, 2012 | 02:31 PM
_Boat_'s Avatar
How about telling us what happened to your other motor...
Old May 11, 2012 | 09:49 PM
KoolBox's Avatar
The engine still in the car,the only thing i know is that it's locked up.
Old May 11, 2012 | 10:15 PM
_Boat_'s Avatar
Well the reason I asked was because I know this little 2.4 is a reliable motor and I haven't read much about them failing. That's the main reason I purchased this vehicle...
I wanted to know what specifically is wrong with yours. Locked up to me means that the crank won't turn. If that's the case then have you had it looked at my a mechanic to see why it's "locked up". Did it overheat or run very low on oil. Is it timing chain related? Have you tried removing the plugs and turning the crank by hand?...
Also what's the history of mods and miles on the motor? I would assume if it's locked up, that it led a hard life...
Anyways, good luck with your motor...
Old May 12, 2012 | 03:54 AM
TrevorS's Avatar
Locked up sounds like it ran very low on oil or coolant or breathed in water (from reading, it's a non valve-piston interference design). What happened? If you really don't know, then if replaced, it could happen again !
Old May 13, 2012 | 06:55 PM
KoolBox's Avatar
well,i think i know what happen,it was raining a lot,and got in a big water poddle,maybe i got some water in the engine,i will take it to the dealer on monday to see whath they say,wish me luck.
Old May 13, 2012 | 08:49 PM
journeyforce's Avatar
I am not sure if Toyota made some mods to the 2.4l engine in the 2008- present XB but if you type 2.4l Camry and head bolts stripped, you will get page after page detailing the issue the 2.4l engine with this(basically 3 of the back headbolts strip themselves out over time and take the threads of the block with them.
Also the 2.4 eats water pumps
Old May 13, 2012 | 10:59 PM
_Boat_'s Avatar
I'll be sure to tell that to my buddy who got 300,000 miles out of his...
I also read that the rear rotors are a dealer only item...
Hydrolocked!...OUCH. Thanks for the explanation. I hope you didn't bend a rod. You should take the spark plugs out and turn the motor by hand to push out the water from the cylinders and then squirt a tsp of oil into the cylinders. If you're lucky, it might start...
Old May 14, 2012 | 02:25 AM
TrevorS's Avatar
What air intake do you have?
Old May 14, 2012 | 03:41 AM
KoolBox's Avatar
Factory intake.
Old May 14, 2012 | 04:38 AM
TrevorS's Avatar
Factory intake.
Factory intake is highly unlikely to be the problem (above transmission air box with looped snorkel that places actual air intake at upper front grill level). Lock up was almost certainly due to something else -- have you checked the oil and coolant levels?
Old May 14, 2012 | 07:43 AM
ScionFred's Avatar
[quote=_Boat_;4014561]I'll be sure to tell that to my buddy who got 300,000 miles out of his...
I also read that the rear rotors are a dealer only item...[quote]
Hard to believe that hardened carbon steel studs could ever pull out of cast aluminum... This is surely exclusive to the 2AZ-FE and crappy Toyota products!
Thanks...
tom0613
Mar 7, 2015 05:59 PM
RayScionXB
Regional - Pacific South
19
Mar 5, 2015 08:22 PM
RayScionXB
Regional - Everywhere Else
Mar 3, 2015 08:27 PM
lexobx
Scion xD Drivetrain & Power
Dec 7, 2014 05:52 PM
