Scion tC 2G ICE & Interior In-car entertainment and electronics...
Wiring for new headunit, never been asked before
Old May 18, 2012 | 01:57 AM
noskatehate22's Avatar
Default Wiring for new headunit, never been asked before
I just got a new navi head unit and I need to tap into some wires. Any help would be awesome!! I need:
Vehicle speed sensor
Constant power
Power when ACC is on
Power when lights are on
Old May 18, 2012 | 04:30 AM
jaspers_xb's Avatar
Speed Sense | blue | ac | radio, white 20 pin plug, pin 3
Radio 12V | blue | + | radio, white 10 pin plug, pin 4
Radio Ground | brown | - | radio, white 10 pin plug, pin 7
Radio Ignition | yellow | + | radio, white 10 pin plug, pin 3
Radio Illumination | Gray (parking lights) ; Blue (dimmer) | + ; - | radio, white 10 pin plug, pin 10 ; white 6 pin plug, pin 5
Sent from my iPad using Tapatalk HD
Old May 18, 2012 | 09:54 PM
That is awesome, thank you!! Just one question: When you say radio, does that mean those are on the plugs for the radio, so when I install the aftermarket wiring harness, I can tap directly into the harness the aftermarket one plugs into? Also, any idea where I can tap into the reverse sensor or whatever for a manual transmission?
Old May 18, 2012 | 10:06 PM
jaspers_xb's Avatar
If you are getting an aftermarket wire harness (not the one that plugs directly into the aftermarket radio) that gives you all the color coded wires for power, ground acc, etc for the radio then you'll just need to match color for color on each harness. And yes when it says radio it's for the plugs behind the radio.
According to the print out I have the reverse wire is a red wire in the drivers kick in the group wires running down the drivers side (make sure you meter the wire. I know in my xb there like 4-5 other red wires in the bundle)
Most harnesses give you 2 illumination wires, one is ground the other in positive, most head units use the positive one (mine does but I also have an aftermarket nav screen) just meter the illumination wire off the harness to make sure.
Sagara09
Feb 28, 2015 06:58 AM
TCnewguy
Feb 16, 2015 03:50 AM
bobc04
Dec 8, 2014 05:01 PM
2002cbr600f4i
Dec 6, 2003 02:01 AM
