header torque specs?
Old Apr 1, 2005 | 02:33 AM
falcon9094's Avatar
Default header torque specs?
Anybody have the torque specs for the header bolts? I want to make sure when I put mine on there is no leaks.
Thanks Justin
Old Apr 1, 2005 | 04:36 AM
chronic's Avatar
thats a good question~!~~
Old Apr 1, 2005 | 06:17 PM
falcon9094's Avatar
anybody?
Old Apr 1, 2005 | 06:31 PM
ScionDad's Avatar
This is all I came up with from someone installing DC header
<snip>
Since I did not have a torque wrench, I tightened the bolts to the point where I thought, "Yeah, it's tight." I've talked to a few mechanics and they do the same. But if you would like to tighten them to spec, the header bolts/nuts are 20 ft. lbs.
Once the header bolts/nuts are tightened, grab your socket wrench with 14mm socket and the spring-loaded 14mm bolts, then shimmy yourself back under the car. Bolt the spring-loaded bolts back onto the b-pipe and header. The bolts will actually stop turning, so listen to the "Jack-in-the-Box" music until they stop. Again, tighten until "it's tight." The torque spec for the spring loaded bolts are 32 ft. lbs.
<end snip>
Old Apr 1, 2005 | 06:38 PM
f1nch's Avatar
yea i have to get mine torqued again soon... after 500 miles you are supposed to haver them re-tightened..
Old Apr 1, 2005 | 06:43 PM
dgHotLava's Avatar
moved...
Old Apr 1, 2005 | 07:07 PM
falcon9094's Avatar
thanks now I can install mine without worrying, and where did you get the numbers out of curiosity
Old Apr 1, 2005 | 07:53 PM
ScionDad's Avatar
searched it here on ScionLife. Located it in the how to section regarding DC Header install
Old Apr 1, 2005 | 08:39 PM
SCIONPARTS's Avatar
exhaust manifold converter to cylinder head 44(N-m) 377(kgf-cm)
27 (ft-lbf)
Old Apr 1, 2005 | 09:21 PM
ScionDad's Avatar
See, thats the problem...mis-information. Sorry for passing that. Figured someone would have called that before now on the old post.
Guess I need to add about 7 more pounds of torque....It's been a few 100 miles now. Can you do a sticky for all the torque specs for commonly modded parts?
Old Apr 1, 2005 | 09:33 PM
mikochu's Avatar
27 (ft-lbf)
I concur with the 27 ft-lbf...
The 20 ft-lbf of torque you read about for the DC header install was for the xA/xB...
Wrencher
Mar 12, 2023 04:54 AM
Hydryman
Feb 23, 2016 03:35 PM
carid
Scion tC 2G Aero & Exterior
Sep 1, 2015 09:08 PM
5N1PE5
Aug 3, 2015 11:25 AM
Subaru86
Jul 31, 2015 04:00 AM
