Wheel and Hub Bore Size.
Old Jun 8, 2012 | 02:54 AM
feldy's Avatar
Default Wheel and Hub Bore Size.
So tonight I tried putting my old tc1 rims on the FRS. Reason being they are my autocross wheels and tire. I could not get the rim to sit flat on the hub of the FRS.
It seems the Hub bore on the frs is larger then the bore on the tc1 wheels. I did try searching but does anyone know what the hub bore size is on the TC1 oem wheels? I'm going to have them machined out a little bit so I can get them to sit flat. Thanks.
Old Jun 8, 2012 | 03:18 AM
masterbB's Avatar
the hub bore on the fr-s is 56mm but idk tc
Old Jun 8, 2012 | 03:33 AM
Jon's Avatar
Jon
Moderator
Moderator
54.1 for the tC1 I believe.
Old Jun 8, 2012 | 03:52 AM
feldy's Avatar
Thanks that's what I thought it was. It's one thing after another. Had to get flat seated lugs in m12x 1.25 that was a pain to find. Now I need the hubs machined out. Just a tad. Or for the wheel pros put there is there a easier way to make a conversion from. 56.1 hub to a 54.1 hub?
Old Jun 10, 2012 | 06:59 AM
doper's Avatar
Welp i did mine today used old wherls from tc for now the hub centric rigs i had to shave them dow bo make it fit but it worked out
It will do for now till i decide on wheels
Old Jun 10, 2012 | 08:42 AM
dropzone's Avatar
Only other thing I can think of is a bolt on spacer with the hub sizing to match appropriately, but I think machining the centers of the wheel might be a cheaper route.
Doper, most aftermarket wheels run a bigger center bore than 54.1, the factory optional wheels from TRD for the tC1 match the bore size. That's why all you had to do was shave the inner diameter of the hub centering ring to 56mm and able to throw the wheels on.
Old Jun 10, 2012 | 05:01 PM
doper's Avatar
Yeah i know but i tell u it was pain in the a$$ lol
Old Jun 10, 2012 | 08:53 PM
Sketch575's Avatar
Hey doper,what size rims and tires did you put on your fr-s?
Old Jun 10, 2012 | 09:34 PM
masterbB's Avatar
what did you use to shave em down?
Old Jun 11, 2012 | 06:52 AM
doper's Avatar
I used my old ones from tc for now they are 225/40R18. Potenza S-04
As far as shaving i used what u see in picture and saw blade but the other side of it and sand paper lol ghetto style but worked fantastic . It took a while on the first one but once u figure out what to do than its quite easy .
B_Real45
Feb 23, 2015 07:30 PM
ptperson
Regional - Pacific Northwest
Feb 13, 2015 04:03 AM
Miqmiqmiq
Jan 15, 2015 03:30 AM
tapetheducks
Scion xB 2nd-Gen Wheel & Tire
Jan 14, 2015 06:25 PM
Alvie
Dec 12, 2014 05:04 AM
