Transmission slippage from 2nd to 3rd and into Reverse when warm
Old Jun 16, 2012 | 04:35 AM
Twinklebee's Avatar
Default Transmission slippage from 2nd to 3rd and into Reverse when warm
Normally I'm pretty good at guessing what's wrong with a car... but that's before all the computer parts came into play.
I have an '08 xB with 128K miles, auto trans, remote start, no major mods and pretty much up to date on all the maintenance. I bought her in August of 2007 in Chicago, Illinois but I moved to Phoenix, Arizona in June of 2008.
About 15K miles ago, I would get an occasional slip from 1st into 2nd while driving. Not consistent, no codes would throw, no check engine light would come on. Every once in a great while, it would happen into Reverse and also 2nd to 3rd gear.
A month ago, I started the car with my remote start (as normal) when I walked out of the door at work and the ECU had crapped out. I had her towed to my mechanic, had the ECU replaced and after two days, took her home. On the drive home, I stopped at a red light and the rpms dipped to below 500 and the car felt like she was going to sputter and jump forward - like an old beater dying it's last death. It happened at every red light and I called my mechanic immediately. Took her back and the mechanic reset the ECU. Took the car home again and now I'm having problems with slippage from 2nd to 3rd gear. The sputter of the low rpms doesn't happen anymore, though. I took the car to my mechanic yesterday and the fluid is the right color, consistency and not burnt and there's no reason why it should be doing this.
The problem is specifically this - After driving the car for at least 45 minutes in the HOT weather in Phoenix, if I accelerate from a stop, the shift from 1st to 2nd is good. The shift from 2nd is a high rpm followed by what feels like a slip from trying to catch the 3rd gear and jump forward in the drive of the car. Normally the second or third jump, it feels like the transmission catches and away we go into 3rd. It doesn't always happen but it does most of the time. The same problem happens into Reverse from a stop - put the car into Reverse and the car feels like it jumps and the gear doesn't catch. Once it catches, it stops.
Any ideas as to what I'm dealing with?
Old Jun 16, 2012 | 11:21 PM
r2d2michael's Avatar
Normally the ECU tells the tranny what to shift into and it has been a known problem on older Toyotas where the ECU starts to fail and tells the tranny to shift all over the place. (2001 RAV4's)
So not only do burn out the ECU but your tranny also. If it is still doing it with the new ECU it could just be a bad tranny. You can find used one for less than 1000 and 20-60k on them on eBay.
Or maybe a bad connection from the shift solenoids
Old Jun 21, 2012 | 03:54 AM
Twinklebee's Avatar
I talked to my mechanic and he's going to look at the solenoids and connections. Thank you so much for the reply.
Old Jun 21, 2012 | 05:06 PM
99_xc600's Avatar
Sounds like the valve body within the transmission
Old Jul 17, 2018 | 01:58 AM
jtmaldonado06's Avatar
Default Help!!
Hi, I know that this was a long time ago but I’m having the same issue with my Scion tC 2006. Do you remember what was the real issue with your transmission , your response will be a lot of help for me ,thanks!!
henry54321
Sep 5, 2013 09:53 PM
Toast_Burner
12
Oct 18, 2012 06:33 AM
MillerRS1
May 22, 2012 04:20 PM
rollergoalie16
Jan 24, 2007 12:06 PM
bikeguy18974
18
Jan 31, 2006 07:38 AM
