Anyone running 205/55/16 on 16x7 +40?
I'm planning to put on Rota Slipstreams - 16x7 +40 on my xA and i'm not too sure what tire I should run. I am thinking of getting 205/55 (im really wanting to go with this size) or 205/50 or possibly 215/50. I would like a wide tire, just not sure if the 215 would be too wide and I would like a 55 to cover as much gap as possible but I am afraid of rubbing. I am lowered on Tein S-Techs as well.
I'm currently running 205/50 on 15x7.5 +32 Konig Retracks
https://www.scionlife.com/forums/scion-xa-xb-1st-gen-wheel-tire-1608/buyers-guide-scion-xa-xb-wheels-14/
WHEEL FITMENT INFORMATION
It is assumed that these figures will work on both the xA and the xB, but most are from xB owner's personal comments.
WHEEL SIZE . . OFFSET RANGE . . TIRE SIZES . . . COMMENTS
19x8.0 . . . . . . . 35 (Front)25(Rear)215/35/19 . . . . Rubs Slightly XB(shim kit)DenZinz
19x8.0 . . . . . . . 40 . . . . . . . . . . . . . 215/35-19 . . . . Rubs under hard cornering
19x7.5 . . . . . . . 45 . . . . . . . . . . . . . 215/35-19 . . . . Rear needs 5mm spacer: DGTLLVR
19x7.5 . . . . . . . 42 . . . . . . . . . . . . . 215/35-19 . . . . No rubbing, rear mud flap trimmed: gregp909
19x7.0 . . . . . . . 42 . . . . . . . . . . . . . 215/35-19 . . . . Rolled fenders & hammered wheelwell: matchbox
18x7.0 . . . . . . . 28-32 . . . . . . . . . . 215/35-18 . . . .foxSCION "no rubbing"
18x7.0 . . . . . . . 40 . . . . . . . . . . . . . 235/35-18 . . . .K4kas no rubbing xB
18x7.5 . . . . . . . 35 . . . . . . . . . . . . . 215/35-18 . . . .Front tire rubs at full lock
18x7.5 . . . . . . . 35-42 . . . . . . . . . . 215/35-18 . . . .Silkywilson et42
18x7.5 . . . . . . . 42(Front)(35)Rear 225/35-18 . . . .Oneslowxa 2"drop tanabe sustec pro
18x8.0 . . . . . . . 28 . . . . . . . . . . . . . 225/35-18
18x8.5 . . . . . . . 28 . . . . . . . . . . . . . 225/35-18
18x9.0 . . . . . . . 31 . . . . . . . . . . . . . 225/40-18 . . . .rampagesd
17X7.0 . . . . . . . 20 . . . . . . . . . . . . . 205/40-17 . . . .quadoptix xB
17x7.0 . . . . . . . 28-42 . . . . . . . . . . 205/40-17
17x7.0 . . . . . . . 40 . . . . . . . . . . . . . 215/40-17 . . . . .TheScionicMan
17x7.0 . . . . . . . 38 . . . . . . . . . . . . . 215/45-17 . . . . xB stock
17x7.5 . . . . . . . 30-40 . . . . . . . . . . 215/40-17 . . . .
17x7.5 . . . . . . . 40 . . . . . . . . . . . . . 215/40-17 . . . .3mm Spacers CBSIMONSEZ xB
17x7.5 . . . . . . . 38 . . . . . . . . . . . . . 215/40-17 . . . .Stock xA Leinad
17x8.5 . . . . . . . 16 . . . . . . . . . . . . . 215/40-17 . . . . Front doesn't rub: Oper8r
17x9.0 . . . . . . . 17 . . . . . . . . . . . . . 215/40-17 . . . . Rear rollled fenders: Oper8r
16x7.0 . . . . . . . 33 . . . . . . . . . . . . . 205/55-16 . . . . Front rubs slightly in front: oj411
16x7.0 . . . . . . . . . . . . . . . . . . . . 205/55-16 . . . . No rubs: The Zeeness
16X7.0 . . . . . . . 35 . . . . . . . . . . . . . 205/45-16 . . . . Stock xB: Pushytop
16x7.0 . . . . . . . 25-35 . . . . . . . . . . 205/40-16
16x7.5 . . . . . . . 38-40 . . . . . . . . . . 215/40-16
15x6.5 . . . . . . 35 . . . . . . . . . . . . . 185/60R15 or 185/65R15 (xB and bB stock sizes)
15x7.0 . . . . . . 38 . . . . . . . . . . . . . 185/60-15 . . . . Stock Size xB
15x8.0 . . . . . . 18(Rear)23(Front) 205/60/15 2" ground control Minsk99 xB
MISC INFORMATION
Scion xA and Scion xB Specifications:
Bolt Pattern
4x100
Center Bore
54.1mm
Nut Size
M12x1.5
Stock Wheels/Tires
15"x6" +38 offset / 185/60R15 xB 185/60R15 xA 185/65R15 bB
37 lbs per wheel & tire
Alloy wheel: 16.7 lbs
Other Vehicles With Interchangable Wheels
Toyota Celica (1988-1989)
Toyota Corolla (1988-2001)
Toyota Corolla Wagon (1988-1996)
Toyota Echo
Toyota MR2 (1986-1990)
Toyota Paseo
Toyota Tercel (1989-199
Toyota MR2 Spyder (2000-)
Scion tC Specifications:
Bolt Pattern
5x100
Center Bore
54.1mm
Nut Size
M12x1.5
Stock Wheels/Tires
17"x7.0" +45 offset / 215/45-17
?? lbs per set
(to be added)
MISC INFORMATION
Bolt Pattern
4x100
Center Bore
54.1mm
Nut Size
M12x1.5
Stock Wheels/Tires
Toyota Echo
Toyota Paseo
Bolt Pattern
5x100
Center Bore
54.1mm
Nut Size
M12x1.5
Stock Wheels/Tires
?? lbs per set
(to be added)
I've got 16x7 Konig feathers with 205/50r16's on them, and while I haven't even had them for a full day yet, I don't believe they rub.
Maybe a smidge at full lock up front, but that's it.
Pictures incoming.
Rear clearance
Front [kind of dark but still]
Front clearance
Pictures incoming.
Rear clearance
Front clearance
Onestepahead85
Apr 28, 2015 07:05 PM
