replacing the clutch
Old Apr 4, 2005 | 05:34 AM
aarontrini85's Avatar
Default replacing the clutch
ok so i was window shoping for a clutch and i found these
http://www.clutchmasters.com/shop/?p...04&ToYear=2005
what is the diffrance between the 1 and the 5? and why is the 5 cheaper then the 3? if any one knows please let me know? i know the 5 can handle the most power but why is it cheaper then 3?
Old Apr 4, 2005 | 07:00 AM
BlakesTC's Avatar
The difference in the numbers represent the stages of the clutch. FX100 to FX500 respectively.
If you look at their homepage, you'll see an image which will give you a brief description of each clutch.
My recommendation is you get the FX300. If you get a race clutch, driving daily will be a real pain, but some can take it and some like it.
I think that the reason why the FX500 is cheaper than the FX300 is probably due to driveablility and demand from consumers.
The 500 will be too hard to drive daily, and the 300 is probably the most all-around clutch for the everyday "enthusiast".
Have you ever driven a car with an aftermarket clutch? If not, try it out first. If your clutch catches too quickly (race clutch) you will need to rev and attempt to ride the clutch for standard accelerations. Also, for inexperienced drivers or the people who tend to rip through their gears, I recommend getting an easier clutch, because if you mis-shift, a racing clutch will not slip... Your trans or your motor will blow before the clutch gives in.
Hope that helps.
-Blake
Old Apr 4, 2005 | 07:59 AM
hahaitzskippy's Avatar
or the difference in prices is because of the material and time it takes to make them?
5 being the easiest to make because its a one type of compound. same goes for 1. either all driveability or all race
while 3 is harder to make because it consist of multiple compounds tryin to maximize performance and drivability.
Old Apr 4, 2005 | 02:01 PM
xnevergiveinx's Avatar
which one do you think will last the longest? one of these, a trd, or a stock? with normal driving.
Old Apr 4, 2005 | 02:20 PM
race clutches have super grip and usually wear out quick because of the compound used is very sensitive. just lik tires. more grip = less life. i dunno anything bout clutchmaster's product. so... your on your own for that question
yhwhdesign
10
Feb 6, 2015 05:00 AM
blh72
Scion xD Wheel & Tire
Feb 2, 2015 12:36 AM
torranosaurus
Jan 28, 2015 04:53 AM
Xaphoon
Jan 17, 2015 02:12 AM
baker08tc
Dec 30, 2014 12:02 AM
