Soo I deleted it...
I bolted on the DC Sports Axle Back and then took it to my local custom shop that a buddy of mine works at and had a Thrush glass pack welded in. On the gas it's a little loud but at speed it's not bad. Not raspy or hondaesque...
I noticed a 600rpm drop at speed (62mph) instead of cruising at 3100RPM I cruise at 2500rpm...created some flow there. Just the axle back netted me 1.8 mpgs so I'm curious to see if I get a few more...almost to 36 mpgs
here are some pictures & a crappy video:
The tumor removed!
The tumor removed!
RPM has nothing to do with exhaust flow, or any other motor modification.
62mph at3,000 RPMs with always be 62MPH at 3000 RPMs unless you are swapping gears or a final drive in the transmission.
Did you change anything in the transmission?
If the answer is no then it isnt.
Just think about it, and think logically about how gears (even the ones not in cars) work. Even though less force may be required to move them now, they will still move at the same speed in conjunction with each other unless one of them is altered.
You look even dumber with that wink face. We wouldn't be so adamant about explaining how your mistaken if we didn't know what we were talking about. So please do not act like you pulled one over on us.
Just so you understand mate. ITs dope that you had that done and im sure the car is performing better. However your RPM rates will never change because of a flow. I have header/intake/2.5 exhaust cat back. n some other things. My rpm wont change. RPM is solely based on gearing.
I understand what y'all are saying but I'm just giving my observation...I could care less @criminaltc what you think, be as adamant as you want, I made a simple observation and was sharing it. I have nothing to gain here...
