Scion FR-S Drivetrain & Power Engine and transmission discussions...
Flywheel & Crankpulley Test fit.
Old Sep 4, 2012 | 10:42 PM
NEROAZUL's Avatar
Default Flywheel & Crankpulley Test fit.
Hey guys,
I'm looking for a FR-S/BRZ owner thats looking to test fit two items. Preferably within the Walnut CA area. Donor car gets to keep parts
I snapped some cell phone pics to give you an idea of what they look like.
Please PM me if you are interested. Thanks for looking.
Old Sep 5, 2012 | 12:28 AM
masterbB's Avatar
do you care if vehicle is an auto? i'm in scv but can make the drive
Old Sep 5, 2012 | 03:19 PM
NEROAZUL's Avatar
You have a PM sir.
Old Sep 5, 2012 | 03:28 PM
TheQuietThings's Avatar
auto has no flywheel.
Old Sep 5, 2012 | 05:01 PM
xB_Toaster's Avatar
Correct me if I'm wrong but don't all transmissions have a flywheel? I'm pretty sure your car wouldn't start without it?
Old Sep 5, 2012 | 07:31 PM
Roller_Toaster's Avatar
As amazing as the upgraded flywheel/pulley was on my xb2, I have a feeling this is going to turn into a "must have" mod for frs's!
Old Sep 5, 2012 | 07:36 PM
mixD's Avatar
I havnt really tore into a scion auto trans but i believe the manual trans has a true flywheel and the autos either have a torque converter with teeth on the outer shell or they have a flex-plate that has the teeth the flywheel has but none of the friction pad parts. It may be different on a scion but thats what i see in every truck i have torn into. looking into the image above though it may work on both if the holes drilled in the middle are for the torque converter to match up to it?
Old Sep 5, 2012 | 07:40 PM
^ I have an xb2 auto trans sitting in my garage right now, this is correct.
Old Sep 6, 2012 | 04:14 AM
Manual car can technically start without a flywheel but will not move. Auto tranny has a torque converter, no flywheel. If it worked that way an auto car would stall at every red light or stop sign lol
Old Sep 6, 2012 | 08:01 AM
masterbB's Avatar
i was more replying to help with the pulley, but I have one already so I'll let another person jump on this
Old Sep 8, 2012 | 02:29 AM
NEROAZUL's Avatar
The holes on the flywheel are what holds in the friction ring, which is the friction surface the clutch disc makes contact with. I can confidently say that it will not work with an automatic transmission as it was reverse engineered from a stock frs/BRZ flywheel.
WRX1316_TcVicent
Jul 22, 2021 06:06 PM
HeatherS0529
Feb 24, 2016 11:56 PM
Hydryman
Feb 23, 2016 03:35 PM
HeatherS0529
Aug 6, 2015 05:29 PM
scion86
Jul 6, 2015 03:27 PM
