Engine Rebuild Help
Old Sep 10, 2012 | 05:32 PM
R3define's Avatar
Default Engine Rebuild Help
Hey Guys.
I just pulled the engine out of my car this past weekend. Did a compression test and cylinder #3 was about 30lbs low. So I'm thinking piston ring. How hard is it to pull apart to replace the rings and do I need anything other then the rings and a gasket set?
Thanks.
Old Sep 10, 2012 | 10:38 PM
sebbyxtc's Avatar
Maybe a hone if your cylinder wall is scarred. New oil of course. Check if the piston is melted/bent at all
Old Sep 10, 2012 | 11:06 PM
R3define's Avatar
Does the hone just smooth the cylinder walls out? And how about getting some forged rods and pistons? Anywhere good to pick those up from?
Old Sep 12, 2012 | 06:07 PM
BlackKnight's Avatar
Music City Scions
If you dont want future issues you need: valve cover gasket, exhuast gasket, head gasket, intake manifold gasket, I would recommend doing thermostat and gasket, have the head inspected and resurfaced or deck if needed. Hone the cylinders have the block inspected, new rod bearings, new cam bearings, main bearings. Have the pistons inspected and piston to wall clearance checked. The bkock will need resurfaced or decked. Dezod or Ptuning are good sources to get parts from.
Sent from my SGH-T999 using Tapatalk 2
Old Sep 12, 2012 | 06:28 PM
R3define's Avatar
Awesome! Thanks for all the info!
Old Sep 16, 2012 | 01:54 AM
Souk's Avatar
im in a simular situation. i plan to replace EVERYTHING in the motor. now i also plan to get forged connecting rods. my friends said to me that i do not need aftermarket rods. idea's ?
Old Sep 18, 2012 | 03:25 AM
sebbyxtc's Avatar
Dont listen to your friend, our rods are our weakest thing in our motors.
Old Sep 18, 2012 | 05:19 PM
Music City Scions
Actually the pistons are but yes you need to upgrade the rods.
RayScionXB
Regional - Pacific South
19
Mar 5, 2015 08:22 PM
RayScionXB
Regional - Everywhere Else
Mar 3, 2015 08:27 PM
Ramroids55
Jan 16, 2015 02:42 PM
TheTripleC
Jan 4, 2015 06:46 PM
bambbrose
19
Jan 5, 2004 05:31 PM
