Scion FR-S Suspension & Handling Coilovers, Shocks, Airbags, Swaybars...
KW V3 Coilovers now in stock!
Old Sep 18, 2012 | 08:32 PM
paul_dezod's Avatar
Scionetics
KAD
Default KW V3 Coilovers now in stock!
At Dezod Motorsports...
KW Suspensions introduces the first Subaru BRZ coilover in the United States! This is the highest quality, with the most race technology coilover available for the 2013 Subaru BRZ.
"Race technology for the road with adjustable compression and rebound damping"
State-of-the-art motorsport technology for proven performance on the streets. The independently adjustable compression and rebound damping allows for custom driving set-ups. The exclusive KW patented system has dual-level valves to provide the adjustment of the rebound damping (comfort) and the compression damping (driving dynamics) in the low-speed range. High-speed settings for driving comfort are preset by KW engineers.
Independently adjustable damping technology (rebound and compression damping)
"inox-line" stainless steel technology*
Individual height adjustment
Infinitely adjustable rebound damping
14-level adjustable compression damping
Unique, independently functioning damping power adjustment
TÜV-tested adjustment parameters
High-quality components for long life
Comprehensive documentation for ease of use
Based on vehicle specifications, the rebound damping is adjusted by a spindle at the end of the piston rod. Mainly, the traction phase (rebound) controls car body vibrations and influences handling and comfort in the low-speed damping range. By using the traction phase adjustment, the vehicle can be fine tuned to the requirements of the driver. Moreover, driving behavior can be regulated from comfortably rolling to sporty and tense with improved road holding characteristics.
The compression phase adjustment is carried out at the lower end of the shock absorber via KW’s patented multi-purpose valve. The large number of pre-set parameters on this valve allow for a wide range of adjustment for individual use. The unique low-speed compression adjustment distinguishes this technology from any other. In this compression range, the driving behavior of the vehicle is drastically influenced. An increase of the damping power supports the vehicle already during compression and therefore avoids rolling and pitching. The directional stability is significantly improved.
More info:
http://www.dezod.com/pd_kw_variant_3_coilovers-fr-s.cfm
FREE OVERNIGHT SHIPPING WHEN GROUND IS PAID FOR
SloTC1
Apr 2, 2015 07:11 PM
TheTripleC
Jan 4, 2015 06:46 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
avus
Dec 23, 2003 03:35 PM
