notchy 5spd
Old Sep 20, 2012 | 03:02 PM
afoulk's Avatar
Default notchy 5spd
Do the 5spds in all the 2nd Gens feel real notchy? I bought my 2012 with 5400 miles on it, and it has shifted like crap from day one. I have to shift it like a dump truck, nice and slow. It gets better once the tranny is warmed up, but never really ever feels smooth. Some mornings, if its cold enough, I'll even get a bit of a "crunch" going into 2nd the first couple times, warmer mornings its fine. I've got some amsoil manual transmission oil waiting to go in it at my next oil change, hoping that helps. I think most of the issue is due to these cars handing onto the revs so long when shifting, not allowing the engine and tranny RPMs to match up fast enough, but I just wanted to see if anyone elses xb shifts like this or if maybe I should have it checked out. My guess is they would just tell me is normal anyways
Old Sep 20, 2012 | 04:31 PM
jetas's Avatar
Yea bro mine feels like that too. Let off the gas before u kick in the clutch. Just a split second before. And shift a lil above 2500.
Doesnt help that the throws are so dam long
Old Sep 20, 2012 | 04:56 PM
afoulk's Avatar
Thanks, I was getting worried. I used to have a dodge ram with the 24v Cummins and the six speed and it shifted about the same, but the clutch master cyl was starting to leak on it, I was worried I might have an issue with the clutch on my scion. I'm guessing the long throws actually help, I would think if they were shorter, that would give the synchros less time to do their thing. I know some guys autox their xbs,, I just couldn't imagine shifting it fast enough for something like that
Old Sep 20, 2012 | 04:58 PM
afoulk's Avatar
On a side note, where is the master cylinder for the clutch on these, I don'tsee one on the fire wall anywhere? Under the dash?
Old Sep 20, 2012 | 04:59 PM
jetas's Avatar
I read somewhere that changing the bushings on the linkage helps but i havent thought of it that much.
Old Sep 20, 2012 | 07:19 PM
Roller_Toaster's Avatar
master cylinder is built into the brake master cylinder. I get a small crunch when I shift into 3rd unless I shift EXTREMELY slow, and I have Royal Purple gear oil in my tranny....I don't know what else to to other than trying to adjust my clutch.
Old Sep 20, 2012 | 08:39 PM
domoboiz's Avatar
Would a short shifter help with this at all
Old Sep 20, 2012 | 09:12 PM
xseveredveganx's Avatar
Utah Scions
I have the TRD Quckshifter, NST bushings, Fortune Auto titanium ****, Weapon-R torque dampener, and Amsoil synthetic gear oil. My shifting is a little notchy, but I like it. Everything is firm and solid, absolutely no slop.
Old Sep 20, 2012 | 09:18 PM
roadrunnergt's Avatar
I've had the same problem. I Got in a 5spd matrix at work. Does the same thing. A friend of mine swears its the slave cylinder going bad. I had it unbolted one day and put it back on and I noticed a slight difference.
Old Sep 20, 2012 | 09:19 PM
TWM_Performance's Avatar
You guys can definitely check out TWM Performance for some cable bushings. It'll make your shift a lot more composed and more certain, increasing driver feedback levels HUGELY! You're going to LOVE our TWM Performance bushings, it's a NIGHT and DAY difference ;)
http://www.twmperformance.com/bushin...ushing-kit.php
Renato
Team TWM Performance
Old Sep 20, 2012 | 11:56 PM
domoboiz's Avatar
I wish you guys woulda or us a short shifter. Had one in my Tc and loved it please make one for the xb
Old Sep 21, 2012 | 12:15 AM
afoulk's Avatar
I just worry about the "crunching" causing premature wear to the syncros, but it sounds like its something we just have to life with
Old Sep 21, 2012 | 02:29 AM
jetas's Avatar
http://axxtion.com/Scion.html
Old Sep 23, 2012 | 05:34 PM
I actually have the shift busings! They are great! This crunch just appeared as it's getting colder though.
I adjusted my clutch pedal engagement a bit, and it's nowhere near as bad.
If I try to shift into third without going :second-neutral-third: (with at least a 1/2 second gap between each part , I get a nice little grind).
Old Sep 24, 2012 | 08:23 AM
AAG's Avatar
AAG
DeepSouth Scions
The stock fluid sucks, I changed it at 5k miles. Tried redline mt-90 and then mt-90/mtl mix and both were ok but sucked in cold weather. Im now 2 years on eneos mtf and its awesome.
Old Sep 25, 2012 | 10:35 PM
afoulk's Avatar
Whats the procedure for adjusting the clutch free travel? I wasn't aware you could do this on these.
Old Sep 26, 2012 | 12:45 AM
There is a write up somewhere...I will check for it.
There is a nut/bolt connecting the pedal to the master cylinder behind the pedal. Adjusting it will adjust the clutch engagement point. the nut on mine had worked itself loose and gotten a decent amount of play in it.
Old Oct 25, 2012 | 01:25 AM
jason605's Avatar
I just start out in 2nd gear and it shifts great.
Old Nov 12, 2012 | 03:07 PM
afoulk's Avatar
Well, I changed my tranny oil a couple weekends ago, and used the Amsoil stuff. So far, I'm not impressed. Its even harder to get into 2nd when cold, and once warmed up, it does go into gear ok, but I can just barely feel the teeth on the sycros mesh as it goes into gear sometimes. Its almost as if the Amsoil stuff is a little "slicker" than the factory stuff and doesn't allow the syncros to slow the gears down fast enough to engage smoothly. I might try the Eneos stuff yet, and if that doesn't work, I might take it to the dealer have the clutch adjustment checked. If its not that, I think I'll just stick with the toyota stuff.
Old Nov 27, 2012 | 02:55 PM
TheMotrCty's Avatar
Dudes! It's a Toaster! Quit power shifting and stuff. LOL
Ronnie
