Keep Blowing Tail Light Fuse? HELP :(
Old Sep 21, 2012 | 04:05 PM
Exclusive_WolF's Avatar
Default Keep Blowing Tail Light Fuse? HELP :(
I bought some After Market Tail Lights the LED ones and
when I connected it to try it then turn it on the fuse blows .
It's the Tail fuse. Any idea what this could be?
Please help
___
Old Sep 21, 2012 | 04:26 PM
TeeCizzle's Avatar
Did you rotate the plug into the connector?
IF you blow a Fuse all you need to do is rotate it and plug it back in.
Try that!
Old Sep 21, 2012 | 09:54 PM
Try that!
Thanks for the responce but it only goes in one way its just a plug and play tail light you cant really flip it :/
Old Sep 21, 2012 | 10:40 PM
TeeCizzle's Avatar
Can you take pics of the Connectors??
What kinda of Tails did u get anyways??
Old Sep 22, 2012 | 12:55 AM
testa422's Avatar
that happened to me when i put my new anzos in...come to find out i had pinched one of the wires against the body of the car when i was sliding the new lights in so everytime i turned them on the fuse blew...easy fix!
Old Sep 22, 2012 | 02:27 AM
deez's Avatar
My new anzo's are doing this now too. FML, i gotta take them out and see what I come up with tomorrorw
Old Sep 22, 2012 | 08:09 AM
AnotherDude's Avatar
Plug and play or not, you should just be able to flip the led connector. Led tail lights are polarity sensitive, they can only go in one way otherwise you blow fuses. Check the connections again. You should have 3 connections that go into one harness, reverse, brake and blinker
Old Sep 22, 2012 | 09:38 PM
Thanks for the prompt responces guys i have auzo aftermarket tail lightsbif that helps here a picture of the connection if it helps let me know !
Attached Thumbnails Keep Blowing Tail Light Fuse? HELP :(-20120922_142212.jpg
Old Sep 23, 2012 | 07:17 AM
dropzone's Avatar
That connection can only hook up one way. It's the other connection with the green wire and one has a stripe(if I recall, installed mine a year ago), match those up correctly and you should have no problem. Before connecting anything I checked how the wires were colored, haven't had any issue. May you get this figured soon.
http://anzousa.com/support/pages/led...n/tC_0507.html
As it says in the instructions, "make sure to match the ground to ground."
sachin1118
Scion tC 1G Aero & Exterior
Oct 24, 2017 12:08 AM
karonos
Feb 24, 2010 12:49 AM
ariese
Aug 12, 2009 05:48 AM
dynamicTC
9
Apr 17, 2009 03:30 AM
SirPhobos1
27
Oct 2, 2007 08:32 PM
