Transmission noise when cold
Old Sep 22, 2012 | 06:06 PM
cress11's Avatar
Default Transmission noise when cold
I have a auto 2010 xb with 14000 miles. I have recently noticed a loud metal to metal noise coming from the front of the car when i put it in gear. It only does it when it is cold It's a high pitch knock sound. Do you think it is the brakes, transmission or axle???
Old Sep 23, 2012 | 03:13 AM
AngHellicTc's Avatar
most likely just your transmission switching gears. noise will happen with the lack of oil around the gears in the cold. I wouldn't worry about it.
Old Sep 23, 2012 | 12:31 PM
RichBinAZ's Avatar
Have someone put it in gear for you while watching the engine, hood up. see if you can locate the noise that way. The engine will move a bit on the mounts, but if one of the mounts has failed it will move a lot and could be the source of the noise.
As mentioned above, it could just be normal.
Old Sep 27, 2012 | 11:55 AM
cress11's Avatar
Default Update
The past few mornings i put the car in gear with the handbrakes up on flat ground and i hear no noise.
Fisqual
Sep 22, 2015 05:51 AM
nazblue5807
Apr 11, 2015 12:20 AM
brownSys
Feb 27, 2015 04:20 PM
evolving_machine
Jan 13, 2015 08:04 PM
gularti
Dec 4, 2014 01:21 PM
