Scion tC 2G Forced Induction Turbo and supercharger applications
Nitrous question..
Old Nov 26, 2012 | 08:42 AM
Hjones1034's Avatar
Default Nitrous question..
Has anyone used Nitrous on a tC2?
I'm trying to figured out what's the limit of how big a shot the stock motor can handle.
___
Old Dec 9, 2012 | 08:47 PM
mytcissex's Avatar
not a lot probably. also running nitrous completely ruins and destroys the engine so not sure why youd wanna go that route, youll end up spending a lot more money repairing.
Old Dec 10, 2012 | 05:46 AM
Hjones1034's Avatar
Nitrous put on about as much ware as turbo does. If done with a right tune its completely safe. The difference with nitrous is your not always spraying so in all honesty I'd like to think it puts less ware than turbo
Old Dec 27, 2012 | 01:11 AM
TurboMonkey36's Avatar
My guess is that you can put as much power safely as you would with a turbo kit. The problem you see with nitrous is when people get a kit, they get a unit that doesn't change too many paramters on or from their ECM as a piggy back does or better yet, a stand alone unit that has the most paramters and room to change fields. This makes them more prone to failing to make power or to make the engine run safely. You could get a kit and run it using a piggyback or standalone, yet it is costly. Realize that you will have the same risk in engine failure as with a turbo kit, without mechanical faults of the turbocharger itself, etc.
Old Jan 30, 2013 | 12:52 PM
darwintheory's Avatar
COMPLETELY WRONG ^^^^ obviously has never ran nitrous ... there's only a risk if you don't set up a safe system ... you can do a 50 shot with out having to do any serious work to the car ... also a wet kit in my opinion is better bc with a dry system you have to upgrade the fuel lines , pump and injectors , where in a wet you don't have to do that unless your running 100 shot or more ... I'm planning to do a 50 shot with a wet single nozzle kit ... dry system is easier to install but you better have upgraded fuel system bc if you ever run lean you will cause major damage to your motor ... for me a wet system is just easier to maintain safe
Last edited by darwintheory; Jan 30, 2013 at 01:29 PM. Reason: additional comments
Old Jan 30, 2013 | 04:46 PM
mytcissex's Avatar
when running nitrous your motor is internals are experiencing temperatures of 1000+ degrees fahrenheit for several seconds at a time. your stock internals are not going to last very long on nitrous.
Old Jan 30, 2013 | 06:49 PM
draxcaliber's Avatar
You know what nitrous does way more often than turbos? http://youtu.be/9bRbd3-Myg0
Old Jan 30, 2013 | 07:23 PM
So do you always quote the 1st thing Google gives you ? Do your home work. You wanna be "If the N2O system has been properly designed to supply the correct amount of gasoline along with the N2O, combustion temperatures will actually be lower than when N2O isn't being used,
so damage from elevated temperatures does not occur. Since the purpose of N2O injection is to make more heat, this may sound like a contradiction, but it isn't. With N2O, the total amount of heat energy released is greater, but the peak combustion temperature is lower."
__________________
Old Jan 30, 2013 | 07:28 PM
Your just as ignorant as everyone else. If you don't install safety precautions then of course your going to blow your motor. If you have a window & time your shot to go only at the appropriate rpms & etc you will be OK.
But if your like Honda & Mustang fanboys & just strap a NOS kit to your car without any or non adequate safety measures then something's bound to go wrong.
__________________
Old Jan 30, 2013 | 09:19 PM
Your just as ignorant as everyone else ... If you don't install safety precussion then of course your going to blow your motor ... If you have a window & time your shot to go only at the appropriate rpms & etc you will be ok ... But if your like honda & mustang fanboys & just strap a nos kit to your car without any or non adequate safety measures then something's bound to go wrong
...and that is what everybody nearly does. They like nitrous because it is cheap accessable speed. faster and cheaper than a turbo or supercharger as long as the bottle is full. but nitrous is far more volatile than properly boosting a car with forced induction.
lastly, do not call me ignorant. I don't know everything, but on this subject, I know enough.
Old Jan 30, 2013 | 09:28 PM
A properly set up N2O system is just as potent as a properly set up turbo/super charger system. All 3 can cause premature engine failure if not properly set up or tuned & have the right safety measures. And I didn't call you ignorant for your lack of knowledge I said it b/c you posted a useless video of a NOS backfire
when I could also Post a million vids of Turbos blowing pistons through the hood of a car. NOS is not for everyone but neither is Turbo or Super chargers ... It's a personal preference & this guy wasn't asking for your opinion on whether you like it or not he was asking how much our engines can handle.
___
Old Jul 6, 2021 | 02:57 AM
GeneralTech's Avatar
Default Common "mist" information lol
Nitrous actually lowers the cylinder temperatures this was demonstrated to me on an old chevy 350 with a 75 shot of nitrous that's job is literally to just do dino pulls all day long on my 2nd day in my power and performance class, Room had a huge banner saying "Nitrous does not blow up engines improper application and use of Nitrous blows up engines" Nitrous has a bad name cuz its cheap and people abuse it.
the_real_deal
Dec 22, 2010 10:06 PM
Alvarado.e09
Dec 22, 2010 08:03 AM
elcapetan
25
Feb 25, 2010 06:03 PM
SCiONRiDER69
31
Feb 27, 2008 09:27 PM
Wonderhut
Jun 6, 2004 12:55 PM
