Replacing my Radiator Mounting bracket..
Old Nov 26, 2012 | 06:17 PM
TPMJB's Avatar
Default Replacing my Radiator Mounting bracket..
So long story short, I hit a deer and bent my radiator mounting bracket, my hood latch bracket, and destroyed my hood pretty good.
Minimal other damage though, which is just luck since I don't have collision.
But I bought this:
http://www.ebay.com/itm/370685691198...84.m1497.l2649
I can't, for the life of me, find instruction on installing it. I assume it's fairly self explanatory and I should start by removing the front bumper (which I cracked, but no big deal).
I'm wondering if anyone has done this before and can provide some instruction. I'm sure I can do it, but I'd rather not reinvent the wheel if someone else has experience with this.
If not, I guess I'll take a ton of pictures for anyone else who might be in my situation.
Attached Thumbnails Replacing my Radiator Mounting bracket..-18280_10151104818750303_1343583327_n.jpg   Replacing my Radiator Mounting bracket..-36309_10151104820085303_848216456_n.jpg
Old Nov 27, 2012 | 01:38 AM
TPMJB's Avatar
Well, good news and bad news:
Bad: A lot of this actually needs to be welded to the frame
Good: The only damaged part was the tie bar, which can be easily swapped out
Bad: I took off way more than I needed to and didn't keep track of which screw goes where lol
Here's some pics of the install. Notice how I was too lazy to paint it. Yeahhh...
Note: Bumper does not need to come off to replace the tie bar.
https://i.imgur.com/7e2YH.jpg - Old tie bar coming off
https://i.imgur.com/GpEBg.jpg - New tie bar in
http://imgur.com/rmBRy - New hood on, not sure if it's not flush because I bent the fender slightly, or if it's because this hood was only $100.80 on eBay with shipping.
I'm going to bed.
Old Jan 14, 2013 | 10:39 PM
sfred's Avatar
I have the same problem but with a little more damage. I also have to replace the vertical part of the bracket on the driver's side.
I was considering buying the OEM exact replacement parts, but there's quite a bit of welding involved.
Now I'm considering buying the same full bracket that you bought. I have everything off (bumper, fender, hood, etc) Is the install easy?
You mention welding, but the description on eBay says it's a bolt-on. Do I have to weld if I'm replacing the entire bracket?
Also, are all holes the same for headlight attachment, etc.?
Thanks for your help
____
ricnoval
10
Apr 6, 2023 05:37 PM
Mytre
Scion tC 1G Aero & Exterior
Sep 2, 2013 01:34 PM
aceshigh6789
Jul 1, 2010 01:42 AM
rallying_the_scion
40
Aug 28, 2008 10:27 PM
rosedaleny806
Feb 11, 2008 04:51 PM
