Scion tC 2G Forced Induction Turbo and supercharger applications
TC2 Turbo
Old Jan 2, 2013 | 04:54 AM
19Nestor's Avatar
Default TC2 Turbo
hi im new to posting threads but I was wondering about how much money will I need to purchase and tune my car if I were to get a turbo kit
Old Jan 2, 2013 | 06:50 AM
Diffraction's Avatar
you would need more than just the kit itself, which are all around 5-6k. a number of things also should be changed to accommodate the turbo, like suspension, for example. Also, money for installation and tuning adds a good amount as well.
Old Jan 2, 2013 | 12:03 PM
scionchicop's Avatar
Look to spend at the least $5,000, assuming you go with one of the bolt-on kits available.
Old Jan 2, 2013 | 03:15 PM
my06tc's Avatar
all depends..you can buy a new bolt on kit around 5-6k.....or you can piece together a kit,for a bit cheaper,or you can buy a used kit.....
then comes the tune,the most important thing,youll ever spend your money on,you can have 10 grand in top end parts on your car,if its not tuned correctly,they will be useless..
list goes on and on...depending on what route you can,DIY or pay someone,will factor in how much you spend
Old Jan 2, 2013 | 07:47 PM
19Nestor's Avatar
thanks...
i dont which turbo to go with cause i like the ptuning turbo kit because i could get the optional red intake which makes it look bad ___....
or the dezod turbo because of the blacked out intercooler...
i saw that ptuning bring a step-by-step instruction on how to install and what needs to be removed....which saves me money which i could use to tune the car....
by the way i got a 2012 scion tc2 cement with tein lowering springs and weapon r neo-chrome intake ....
looks tight....
cause that the best way to go if i want to improve my power cause if i go with other things i wont get much power and will be spending about the same....
Old Jan 3, 2013 | 04:56 AM
Kyleptrsn1's Avatar
Here's what I spent: I did install myself.
Turbo: $5500
Gauges and gauge pods: $300
Clutch: $400
Tune: $600
I got a quote from a shop on how much it would cost to install and they wanted $5000 for the turbo and clutch install.
Old Jan 3, 2013 | 12:43 PM
19Nestor's Avatar
thaks....
for the info and it wasn't that hard to install it right
Old Mar 2, 2013 | 12:05 PM
Rydrdg's Avatar
Originally Posted by 19Nestor
thaks....
you can install and save money.then get a tune for decent power and run stock clutch. get sports spring and short shifter and a front strut tower bar you be strait.
Old Mar 29, 2013 | 12:17 AM
ZeroEyeQueue's Avatar
If you don't know what you're doing, get a professional to help. It takes some cursory auto knowledge to do it correctly.
Suspension stuff can wait, and get a new clutch. The stock one will not last long, otherwise.
If you're installing yourself, plan on buying new plugs, fluids and the proper filters.
Our cars weren't meant for forced induction, so do it right the first time to avoid a more costly repair bill.
A1_Fares
Regional - Pacific Mid
Jul 6, 2015 02:48 AM
2012TC
Jun 15, 2015 07:00 PM
clickclickw00t
Feb 18, 2015 08:57 PM
BrokenTC2
Jan 27, 2015 03:32 AM
greytc
Dec 8, 2014 05:06 AM
