Low car idle problem
Old Jan 20, 2013 | 09:14 AM
brentsonk's Avatar
Default Low car idle problem
Hey i have a 2005 Scion Tc. I have a cold air intake for it, and i dont have a panel underneath the car. Like when i drive water goes into the engine compartment and thats not good, but when i did put a panel, my car doesnt have enough air flow to the intake so when my car idles, it idles to low and then it dies. IF anybody has this problem, please let me know how to fix it
Old Jan 20, 2013 | 09:35 AM
Dam262a's Avatar
I doubt that has anything to do with the panel on the bottom because I don't have 1 and I don't have a problems. Check your throttle body that might be very dirty if not check your mass air flow sensor that could be also very dirty.
Sent from Tapatalk HD
Old Jan 20, 2013 | 11:47 AM
Jan06xB's Avatar
Sounds like what he said or you have an air leak after the air flow sensor.
Old Jan 20, 2013 | 04:56 PM
TimmerTC's Avatar
Or the intake piping is too big. What kind of intake do you have?
Old Jan 20, 2013 | 07:07 PM
That_Kid_Ju's Avatar
Or convert to a short ram intake and not worry about water getting to the filter. On N/A cars it doesn't actually make a significant difference in terms of performance gains. You get maybe 2 or 3 hp (depending on the design). Looks and sounds nice tho.
Old Jan 21, 2013 | 06:45 AM
brentsonk's Avatar
thank you!
Old Jan 22, 2013 | 05:20 AM
Sleeper_TC's Avatar
Post
More likely its gonna be your MAF sensor...
i had this same problem not to long ago where my car started up just fine but when it warms up it was jumping from like 1000rpm to 4000rpm. it would idle like below 1000rpm right? my chick had the same problem today too with her short ram intake on the m35.
go get some brake cleaner (chlorinated or something like that) and spray the crap out of your MAF sensor (gotta remove from adapter port first) than let it dry than put it back on and try it again. it shouldn't take that long cause brake cleaner dries real quick.
give that a shot and see how that goes, try getting a heat shield for your CAI since its down there.
Old Jan 22, 2013 | 04:45 PM
TimmerTC's Avatar
Just to be on the safe side I would buy maf sensor cleaner from crc cs it's specifically made just for that.
Old Feb 4, 2013 | 06:37 PM
VolcomJonny's Avatar
That or there's a restriction in your air filter. Get a damper for your long ram and prevent that hydrolock.
Old Jul 4, 2013 | 02:54 PM
IzmolioXB2's Avatar
Did you fix it Brent?
cid_mcdp
Jan 5, 2015 02:45 PM
TheTripleC
Jan 4, 2015 06:46 PM
fluxingnation
Dec 26, 2014 04:28 PM
rcflyer15
Dec 5, 2014 05:15 PM
eric_m
79
Mar 17, 2013 12:21 AM
