xB 10's wide ?
Old Jan 28, 2013 | 03:59 PM
HUEZO's Avatar
Default xB 10's wide ?
Got a few Q's
I wanna run 15x8 + (?) Up front and 15x10 (+0?) rear
I read a few different reviews.
What kinda spacing/camber would I need in the rear? If it were possible 10's up front but what kinda spacing would be needed?
I'm still new to wide and aggressive stances
so any help would be appreciated
Alex
Old Feb 7, 2013 | 11:48 PM
Maineman's Avatar
Default 15x10
I'm currently making a set of 15x10 Steelies I'm using the stock steel wheels and a set of 15x8 Chevy rally wheels. Since for the back side I used the stock wheels there should no need to change anything. I'm almost done with the first wheel I'll keep you posted as I go.
Old Feb 10, 2013 | 03:53 PM
usnrocker's Avatar
id love to see a 10" wide wheel all round on a box.. i think the insanity of the size alone will make it hot
Old Feb 10, 2013 | 04:55 PM
DaWiz711's Avatar
Maineman, how are you keeping the wheel true? Very interested in this, the only local shop that widens steelies quoted me 360$ per wheel for rebarreling!
Broadcast by Cambot aboard the Satellite Of Love
Old Feb 10, 2013 | 10:06 PM
Metalcoffin's Avatar
Euro Poke- recommended air, or at least stiff coilovers
15x8 +0, 15x9 +0
16x8 +0, 16x9 +0
Here's a little chart someone on another forum made.
Conservative Flush- springs, coilovers, or air
15x7 +20, 15x7 +10
16x7 +20, 16x7 +10
17x8 +30, 17x8 +20
18x8 +30, 18x8 +20
Hella Flush- springs, coilovers, or air
15x8 +25, 15x8 +10
16x8 +25, 16x8 +10
17x8 +24, 17x9 +24
18x8 +24, 18x9 +24
EXE/Lux- coilovers or air
15x8 +20, 15x8 +10
16x8 +20, 16x9 +20
17x8 +20, 17x9 +20
18x8 +20, 18x9 +20
VIP- coilovers or air (planned for -3 camber in rear)
17x8 +15, 17x9 +10
18x8 +15, 18x9 +10
Extreme VIP- stiff coilovers or air (planned -6 rear, -3 front, pulled fenders)
17x8 +0, 17x9 -10
18x8 +0, 18x9 -10
Sporty Flared- air
15x8 -20, 15x9 -25
Old Feb 10, 2013 | 10:11 PM
And 10inch wheels will poke out, need to go with a zero offset if I remember right.
Old Feb 11, 2013 | 05:39 AM
Here's a handy calculator just came across, http://www.fitmywheels.com/
Old Feb 11, 2013 | 04:07 PM
HUEZO's Avatar
Thanks for the reply man ! Thanks keep me updated !
Old Feb 11, 2013 | 04:11 PM
HUEZO's Avatar
Replys *
Old Feb 11, 2013 | 04:22 PM
HUEZO's Avatar
I was doing 15x10+12 ( for rear )
Old Feb 11, 2013 | 04:23 PM
You're welcome. Have to post some pics once you get your B setup.
Old Feb 11, 2013 | 04:24 PM
I'd make sure you test fit those before you buy. Not sure if they'd rub on the inside lip.
Old Feb 11, 2013 | 04:27 PM
HUEZO's Avatar
I'm debating the +12 or +6 but yeah need a few more measurements but as for the pics I will for sure !
Pm sending
Old Feb 11, 2013 | 04:45 PM
"These are Cragar's, not Diamonds. Not spacer needed. Specs were 15x10, 0 offset up front, -20 in the back. 1" shortened rear axel."
Not sure what he did to shorten the rear axel?
Original post is here:
http://www.clubxb.com/forums/showthr...=19319&page=28
There's tons of info and different setups in that thread.
Old Feb 11, 2013 | 04:58 PM
HUEZO's Avatar
How does one get shortened axle ?
Old Feb 11, 2013 | 05:21 PM
I'm not sure what or why he did that. Seems like that's just making more work for yourself. If he went with a 0 offset on the rear instead of -20 that would essentially put the wheel at the same spot.
Old Feb 12, 2013 | 02:37 AM
HUEZO's Avatar
Hmm so would 15 10 +0 be better than getting +12 or +6?
mischman
Sep 15, 2015 03:38 PM
jnesselroad
Sep 15, 2015 06:57 AM
vancouverray
Scion xB 2nd-Gen Wheel & Tire
Aug 14, 2015 11:47 PM
chunkescion
Aug 13, 2015 09:14 PM
umnitza
Jul 25, 2015 07:54 PM
