"0" offset !!!
Old Feb 15, 2004 | 06:09 PM
MyBoX's Avatar
Default "0" offset !!!
Hello Everyone, I know what offset means and does but when they say "0" offset, does that mean it will push the wheels all the way out?, thanks Sean
Old Feb 15, 2004 | 06:16 PM
sithscripter's Avatar
Either of:
1. The mounting surface is right at the center line of the wheel. Which would push it way out, but not as far as a negative offset.
2. Someone forgot to enter the actual offset into the database and the value defaulted to zero.
Old Feb 15, 2004 | 06:20 PM
superjeer's Avatar
lol, I'm guessing #2.
Check this out, it helped me understand what I needed to know:
https://www.scionlife.com/forums/viewtopic.php?t=348
Old Feb 15, 2004 | 07:03 PM
MyBoX's Avatar
Thanks for the replies guys, Hope it's the second situation, but if it actually has 0 offset would it work on Xb on 16x7 or 15x7 wheels??, Sean
Old Feb 15, 2004 | 07:40 PM
DJ_X_Trodinaire's Avatar
there actually 0 or negative offset
ford aerostar has 0 offset
daytons spokes or for low riders
Old Feb 15, 2004 | 09:14 PM
What's the wheel?
Old Feb 15, 2004 | 10:07 PM
MyBoX's Avatar
DT-05R, that's the name he gave me for them, Sean
Old Feb 15, 2004 | 10:19 PM
EL_PAALO's Avatar
If you're talking about the wheels below, I don't think they're even offered in the correct PCD.
http://www.tougefactory.com/dt-05r.htm
Old Feb 15, 2004 | 10:44 PM
MyBoX's Avatar
WoW, thanks for the link, that's the one but as you mentioned they are only in 4x114.3, I better call the guy again to see what he has, thanks Sean
Old Feb 16, 2004 | 02:42 AM
silkywilson's Avatar
Alot of Datsuns use a "0" offset.. 510s and 240Zs..
Old Feb 21, 2004 | 12:45 AM
Kendo's Avatar
Default 16×7 ET0
7" width wheels with ET0 would be way too aggressive on a Scion (assuming you don't have fender flares). The wheels would stick out of the fenders close to an inch per side in the front, and probably about a ½" per side in the rear.
Old Feb 21, 2004 | 03:01 PM
2fixA's Avatar
ooh, oooh, the old mini-truck look!! hrm, well the lowest I've seen is the teens offset on M@'s xB, search for "M@ Camber", should be the first thread... but a little extra than flush doesn't look bad on the xB
Old Feb 22, 2004 | 04:13 AM
MyBoX's Avatar
Thanks for the info guys, Sean
Old Feb 22, 2004 | 05:10 AM
DenZinz's Avatar
The Veilside 350z has a - offset in the rear...The car is sick!
I actually saw it tonight on the transistion from 605n to 91 e.
Old Feb 26, 2004 | 01:22 AM
ScionVan's Avatar
You guys should see wheels with negative offsets in the teens, and widths in the teens too. Vipers would be jealous...
M@ and Wes has seen them. I'll post pics in a little while.. :)
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
Feb 29, 2016 05:39 AM
terrye
Sep 26, 2015 12:24 AM
xBrelease08
Sep 13, 2015 04:39 PM
umnitza
Sep 1, 2015 08:06 PM
TOOSLOW
Jul 25, 2015 05:19 PM
