Pioneer AVH-P1400dvd Please help me please :( installing now
Old Feb 24, 2013 | 04:31 PM
Tc2009luv's Avatar
Big Sky Scion
Default Pioneer AVH-P1400dvd Please help me please :( installing now
2009 is my car year and I just need to know am I matching the wires colors (green to green yellow to yellow etc.) with the adapters or does it need to be a specific color code match?
also is there anything else I need to know?!? thank you!!
p.s. i know i have to electrical tape tips if this is correct
Attached Thumbnails Pioneer AVH-P1400dvd Please help me please :( installing now-photo_1.jpg   Pioneer AVH-P1400dvd Please help me please :( installing now-photo_2.jpg
Old Mar 8, 2013 | 01:51 PM
iamtC1's Avatar
Look at the head unit manual then the radio harness fir ur car to match the wires, sometimes these things dont color-match.
Old Mar 8, 2013 | 02:51 PM
Demoplay's Avatar
if it's a metra harness you bought should be plug and play. same colors and everything.
Old Mar 13, 2013 | 01:10 AM
atticus570's Avatar
I can let you know if you take the park brake cable for the dvd menu and you want it to function with out the e-brake engaged ground the wire then run enough into your glove box or wherever you want to mount it with about 6inches or more from the ground side then cut the cable so you have two end coming into your glove compartment one from the ground and one from the hu unit. connect them using a basic toggle switch that way you can just toggle the switch to imitate the system be grounded for the first time after you turn the car on. If you just ground the e brake cable it will work but once you turn the car off then back on it wont work that why you need the switch
Old Mar 25, 2013 | 05:20 AM
tracysilverscion's Avatar
It all should be color coordinated. Buy a toggle switch and put in an accessory slot.that way you can. watch TV while driving lol.
Old Mar 25, 2013 | 05:36 AM
Metalcoffin's Avatar
Don't use a toggle switch, use a relay and connect the remote signal wire and the ebrake signal wire to it and ground the other two sides, done! Can even do it all behind the headunit so no one will ever see it and you don't need much wire.
Old Mar 25, 2013 | 05:38 AM
I doubt he's gonna figure out the relay bro toggle switch is much easier for him. Its also nice to turn the key and not sorry about a switch!!
Old Mar 25, 2013 | 05:44 AM
Eh, you might be right, but if he wants to try here's a pic and it looks like there's tons of diy video's too.
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
clickclickw00t
Feb 18, 2015 08:57 PM
cwong1001
Dec 3, 2014 03:30 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
