Offset question.
Old Apr 9, 2005 | 07:03 PM
987KEITH's Avatar
Default Offset question.
Will a 15x7 +20 work in the back of the XB?
Thanks.
Keith
Old Apr 9, 2005 | 07:10 PM
Cockpit_XB's Avatar
Admin Emeritus
+20 offset should work, im supposed to be going w/ 16x8 wheels w/ a +25 off set. But im not absolutely sure about, so hopefully someone can either back me up or knows for sure.
Old Apr 9, 2005 | 07:12 PM
987KEITH's Avatar
thanks for the quick response.
Old Apr 9, 2005 | 08:20 PM
bBOXD's Avatar
Yes that will work for sure.
Old Apr 9, 2005 | 09:28 PM
squirrel's Avatar
Default Re: Offset question.
Thanks.
Keith
Yes, you'll be fine.
Old Apr 9, 2005 | 10:38 PM
987KEITH's Avatar
thanks guys! I'm planning on running a 15x7 +38 in the front but is it possible to run the 15x7 +20 all the way around?
Old Apr 15, 2005 | 02:57 PM
RuntoxB's Avatar
can a 205/50 work with 15x7 with 20 offset in rear?
Old Apr 15, 2005 | 06:15 PM
Bull's Avatar
You shouldn't have any problem with +20 on all 4 corners.
Old Apr 15, 2005 | 06:18 PM
bBOXD's Avatar
Yes the 205/50 will be fine on all four corners.
The +20 will be fine on all four corners too.
I would also run some One Ton Garage Spacer shims in the rear to bring it out a little bit more. It'll look realy good with that +20 in the front. You shouldnt run into any rubbing problems either.
Old Apr 15, 2005 | 06:21 PM
JDMJim's Avatar
You should use a +25 in the front
Old Apr 15, 2005 | 09:22 PM
RuntoxB's Avatar
Thank you Marc. This is the information I have been looking for.
Old Apr 16, 2005 | 02:13 AM
bBOXD's Avatar
No problem at all. Please post pics once you get it all together. What suspension are you planning on running? Better drop that baby to the GROUND.
-Mark
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
Feb 29, 2016 05:39 AM
terrye
Sep 26, 2015 12:24 AM
xBrelease08
Sep 13, 2015 04:39 PM
umnitza
Sep 1, 2015 08:06 PM
TOOSLOW
Jul 25, 2015 05:19 PM
