Scion xB 2nd-Gen Forced Induction Turbo and supercharger applications...
Are ZEX nitrous kits potentially universal?
Old May 10, 2013 | 01:30 AM
pyroman131's Avatar
Default Are ZEX nitrous kits potentially universal?
REDACTED
Old May 12, 2013 | 09:07 AM
ScionFred's Avatar
Run away! Even a "baby bottle" kit specifically designed for your car is a very risky proposition unless you spend the necessary money to obtain a safe and reliable kit. The problem with nitrous is that you're adding extra oxygen without adding extra fuel which results in a lean condition. Lean burn = high EGT = burnt pistons. Well, that's a dry kit. A wet kit should be better but they still have to be carefully calibrated or you run the same risk. A wet kit adds fuel (gas) but as it poorly measured with no dynamic adjustment, it is still fairly risky. A safe dry kit could add as much as 25hp and a properly tuned wet kit could safely add 75hp or possibly more.
hampton1100
May 28, 2015 07:32 AM
yhwhdesign
Mar 7, 2015 02:01 AM
LzeroKI
Scion tC 1G Aero & Exterior
Feb 10, 2015 07:28 PM
tc_Jake
Dec 31, 2014 01:45 AM
spawnconnery
Dec 18, 2014 08:38 PM
