Scion tC Battery Terminal
Old Apr 10, 2005 | 10:37 PM
WarrenSteve's Avatar
Default Scion tC Battery Terminal
yo. I looked around and found nothing on this. Anyone who as added an amplifier to a tC must have added some sort of clamp to thier batter terminal. I have never owned a top post battery so this is a bit new for me.
I noticed it has one rougly 4awg and another smaller, maybe 10awg going to the battery.
What battery terminals did you all use?
thanks! -Steve
Old Apr 10, 2005 | 10:40 PM
engifineer's Avatar
Default Re: Scion tC Battery Terminal
thanks! -Steve
You can buy the top post clamps anywhere they sell car audio.. they will have the hole for the battery cable and one for the amp wiring. I think even Best Buy sells them. Just make sure you buy a good one with very good clamps for the wiring, especially the starter cable.
Old Apr 10, 2005 | 10:43 PM
ya ya, i know, they have them all over, But our battery has TWO wires on it already. Most clamps i see have only 2 inputs/outpus. Which means i would have no place for my amp wire.
Old Apr 10, 2005 | 10:49 PM
engifineer's Avatar
There should be room for the two existing... most all cars have two wires coming from the terminal to start with. One to the starter (big wire) and one to the fuse box. I hate not having the ends soldered to the cables as they build oxidation and deteriorate faster, but when adding an amp wire I think that is your only choice unless you use a small torch to solder it all into the terminal end.
Old Apr 10, 2005 | 10:50 PM
one to starter and one to fuse box? where does the alternator come in there....
Old Apr 10, 2005 | 10:57 PM
engifineer's Avatar
Sorry... fusebox/alternator.... Not sure where the two meet on the tc....
Old Apr 10, 2005 | 11:06 PM
regardless... i just want some links or pics on what people have used.
Old Apr 11, 2005 | 05:16 PM
mandos's Avatar
I just used 0 AWG ring terminals. I'll see if I can't get a picture taken sometime for ya.
Old Apr 11, 2005 | 05:20 PM
you mean just a standard crimp style ring terminal? there must be a better way...
Old Apr 11, 2005 | 06:42 PM
mandos's Avatar
Nah, I used the set screw style 0 AWG ring terminal from Knukonceptz.
Until I throw in my Yellow Top and the rest of that stuff, it's the easiest thing to do while using the stock harness, IMO.
Old Apr 11, 2005 | 08:11 PM
do u have a pic of what you did anyways?
Old Apr 11, 2005 | 08:49 PM
mandos's Avatar
Sorry it's taken so long man. Busy day at the office here. Once our UPS pickup happens in about 20 minutes, I'll get the pic uploaded. Thanks for waiting
Old Apr 11, 2005 | 09:17 PM
mandos's Avatar
There it be Not the prettiest, but it works fine.
Old Apr 12, 2005 | 01:17 PM
SCI_TC_GUY's Avatar
^^^werd.....
Old Apr 12, 2005 | 01:32 PM
toastbox's Avatar
A trick I've seen work really well is to put some wheel bearing grease on your terminals. It might not look super pretty (like if you're showing the car) but it works awesome. A friend of mine does it to his once a month. I've *never* seen any kind of oxidation on his posts. You don't have to cake it on there, just lightly coat it.
Old Apr 12, 2005 | 05:18 PM
thanks mandos, that is how im going to do actually.
should work good. i didn't really notice that screw had that much extra thread. thanks!
-Steve
Old Apr 12, 2005 | 05:34 PM
mandos's Avatar
-Steve
It's kinda close, since that terminal is almost 1/4" thick...but good enough to make a nice connection
ScionRo
Jan 2, 2015 07:54 PM
randode
44
Jun 29, 2004 04:19 PM
foxSCION
13
Dec 3, 2003 05:40 AM
