How Much Time does it take to install springs on Box?
The rear springs tkae abot 30 minutes. The front take about an hour. hour and a half. There's a good tutorial on here on how to do it and it is easy. I wouldn't pay someone to do it.
If you are going to pay a shop to do it, that has a lift and air tools, one hour max. If you and a friend do it in a driveway w/ handtools, you can do it in an hour.
The rears ccan be done in less than 15 minutes w/ two people. One jacking up the car while the other unbolts the shocks. Pull the OEM springs and set the aftermarket while slowly lowering the car and setting in the shocks.
As Jon stated, just yourself, about an hour an a half.
I just changed mine out this past weekend. Back in the winter I checked on prices at about a half dozen places. Best price was $200 (2 places quoted this) amd the highest was $500. Seems to be way cheaper on the west coast.
Book time states something like 4 hours. I did it myself in the driveway in about 3 hours. I have heard others state that they can change them in under an hour. I could do it faster if I did it again but I don't think I could do it in less than a hour. I did use a spring compressor and that takes more time. You don't need this to take them apart (tried one with the tool and one without). Came apart just fine. Just sprung out about a foot. Just be ready for it and aim it away. I did need it to compress the H Tech springs to get it back together. If I had a helper then maybe I could have done it without the tool. If you are dropping more than that, it will be even easyer to put back together.
Try doing a search. Many posts on this here.
Good luck
Good luck
Originally Posted by scottwood2
30 Mins?
Are you related to the Tasmanian devil?
I remember from Bugs Bunny that he was very quick once he started spinning.
I think Randode can do it around 30 minutes or so also.
I didn't use a spring compressor either. I just laid out the OEM strut on a piece of carpeting and unbolted to the top hat.
No need for the compressor for reassembly either.
Even if a shop's rate is $75/hour, it shouldn't take them more than that when they have a lift and airtools.
The "book" time is for dealerships, and dealerships are in the business to make money. Some dealerships are alot more competent than others, and will only charge the time that was actually spent on the vehicle, but others charge "book" time.
Originally Posted by SUPASCIONXB
Originally Posted by squirrel
no need for the compressor for reassembly either.
I too did my Goldline by myself, took me 1 hour 45 minutes,
and I was really taking my time and being carefull. A good
shop with the proper tools could kick it out (on a box) in
an hour.
I was really surprised by how easy it was. I'm glad you guys
are also doing it yourself. There is no way I'd pay a shop
more then $100 to do it for me.
Also, did you guys get your boxes aligned afterwards?
I've been told by about a dozen people it's not needed, but
mine is for sure off a bit. I need to get it done, I've just not
gotten around to it. I'm really worried about the dealership
scratching up my rims while aligning things.
an hour.
sIcKsCiOnS
Originally Posted by Rip Van Winkle
did anyone who didn't use the spring compression tool happen to take pics and do a step by step tutorial?
