205-40-17 on 17x7 with a 40mm Offset- Problems?
Old Apr 13, 2005 | 07:38 PM
Thiat302's Avatar
Default 205-40-17 on 17x7 with a 40mm Offset- Problems?
I did a search and found two different answers. Im no professional when it comes to rims and tires, so I need advice- Will these rub or overwork my engine? These are the tires that www.wheelguyz.com are supplying with the rims in a package. I just want to make sure Im not going to hurt the engine or any other components.
205-40-17 on 17x7's with a +40mm offset-
Thanks in advance for your help!
Travis-
Oh yeah, I do A LOT of highway traveling-
Old Apr 13, 2005 | 07:42 PM
BOXMAN's Avatar
No problems at all I run a 17x7.5 40mm offset and i run a thicker tire 215 40 r17. Plus i am lowered on Tein S techs
Thiat302's Avatar
I read on here that it was better to run a 205-45-17
Any truth in this?
Old Apr 13, 2005 | 07:44 PM
BigBaby's Avatar
no problems at all. that's probably the most commonly used size of wheel/tire combination. like boxman stated, you can even drop your box with no problems on that setup.
Old Apr 13, 2005 | 07:45 PM
Thiat302's Avatar
Excellent- Only concerned because I read a post on how the 40 puts added stress on your engine- or "overworks" was the term that I read. I do a lot of highway driving and thats the last thing I want to happen!
Old Apr 13, 2005 | 07:50 PM
BOXMAN's Avatar
No stress All biger wheels do is increase rolling resistance. So you notice a loss of power and mpg. Nothing major. i run the 215/40/r17 due to the side wall being thicker. Thicker sidewall=better ride on the HIGHWAY!!! you can see my box in my profile or i have a post in the general Xb forum. Or pm me
Old Apr 13, 2005 | 07:56 PM
Thiat302's Avatar
I thought that first number was the section width of the wheel, and that the second number was the height of the sidewall?
Old Apr 13, 2005 | 08:05 PM
BOXMAN's Avatar
they get the second number by dividing something into the width. Also when searching online i used a tire size calculator. and for the Xb 215/40/17's were only 1%off from stock so i went with them
Old Apr 13, 2005 | 09:36 PM
squirrel's Avatar
Default Re: 205-40-17 on 17x7 with a 40mm Offset- Problems?
Travis-
^^No problems with either the fitment, tire, or engine, but you may be happier w/ either the 205/45-17 or 215/40-17, which I used to run. I did mainly freeway driving also, 160 miles round trip daily.
Old Apr 13, 2005 | 09:51 PM
eXciteBox's Avatar
Signature Visions
middle number is aspect ratio of the sidewall
Section Height ÷ Section Width = Aspect Ratio
section height = (overall tire diameter - wheel diameter)/2
info was taken from http://www.yokohamatire.com/utcustom.asp but i figured id post some of the equations here
terrye
Jul 11, 2015 11:54 PM
Onestepahead85
Apr 28, 2015 07:05 PM
smilygo
Jun 29, 2005 10:43 PM
debris
Dec 16, 2003 11:50 PM
scioninla
Oct 30, 2003 08:01 PM
